Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 40
    Jun 2009
    Bristol, Connecticut
    Would you run this cylinder head- in this condition-?
    Would you run this ?damaged? cylinder head on a budget build?
    Picked up a 94 FF block sitting on a pallet with leaves n dirt over it for $175. A piston was sticking, looks like the gasket let some sand/corrosion in
    Here is dirty and then cleaned up best I could
ID:	470594Click image for larger version.
ID:	470593Click image for larger version.
    Jun 2009
    Sacramento Ca
    I would not, only in a pinch till I could get a replacement
  3. Thanks Aaronhl thanked for this post
    Houston, TX
    Yeah, that kinda sucks, bud
    Jun 2018
    Floating around
    Soda blast, Mill, CC it and see if that will work for you. Mill and finish the other side to match. Can always hand sand or hand finish the shape too. I’m sure there are quench profiles here somewhere you can find to upgrade performance. Most of this work is all elbow grease and very little cost. Failing that there is always welding and reshaping. It doesn’t look that bad to me from the pics at least. Could be as simple as polishing the chambers and getting it milled. Lots of options
  6. Likes keefallan liked this post
    Jul 2020
    Planet X
    The last pick doesn't look that bad too me, you could try sandblasting it a little too. Just not too much and not the mating surfaces.
    As long as the mating surfaces are still level and not porous or cracked it will probably work. However if the mating surface is eaten away you need to get it milled and flattened.
    When a gasket fails there's always the risk that something else is wrong though so check for anything weird and misaligned.
    If you try it I'd give it a gentle break-in, varied low to medium rpm and low load for the first 3-4h.
    MIAMI FLORIDA
    I dont see any pitting in the gasket fire ring area, the pitting tn the squish area doesnt look any worse than the factory lost foam surface in the combustion chamber. I would bolt it on check compression... make sure that the plug/piston tops not miky or have dots of water after a test run ,run it on the lake check it again and enjoy.. tons of motors running around with dinged up heads from ring failures with no issues.
  9. Thanks Aaronhl thanked for this post
    Likes David - WI, keefallan liked this post
    ...i would not use it...
    dimpling, that cost extra
  12. Likes keefallan liked this post
  13. #9
    Jun 2009
    good info everyone...The squish area does have some slight pitting but looks like the gasket area is ok, see pictures
ID:	470634Click image for larger version.
    Jun 2018
    Floating around
    A quick soda blast and you would never be able to tell there was any shmoo on there. You can also use scent free oven cleaner but it does eat aluminum so you have to be careful. Practice on some other aluminum first. It does bring aluminum back out brilliant bright clean. Wash thoroughly with water and spray with WD40 after to protect
  15. Likes keefallan liked this post
  16. #11
    Jun 2009
    Ok experts here another few for you
    Seems like the stuck piston had been replaced before, it was the only piston with a center dot on the top of it, the other 5 did not have the dot, any ideas on why this one had the dot?
    When putting a piston back in, if I do not see “UP” because of carbon build up, what is the positioning in relation to the rod n cylinder?
    I think this piston wasn’t put in correctly because the rod part number wasn’t facing the flywheel. Is that required according to the manual?
    Quote Originally Posted by H2OPERF View Post
    Parts with those lost foam "big pores" welds marvelously …
    I got tired of jigging and fixturing up every part that had rot , warpage , or a surface cleaned via chisel mechanic , just to take a skim cut. I got a 16" x 96" belt sander .. wax on ~ wax off , Mr. Miyagi .. done ..
  18. Likes LakeFever, rgsauger, keefallan liked this post
  19. #13
    Sep 2017
    Ashland city tn
    Quote Originally Posted by Aaronhl View Post
    I had put mine out of a runnin 150 in ultra sonic cleaner and barely seen the up and down. Without seeing that idk how u would do it.
  20. #14
    Jun 2009
    Quote Originally Posted by Merc 2.5 View Post
    I think I could tell by the location of the ring pin gaps and the skirts of the piston. Could anyone explain the piston positioning or does it look symmetrical by eye?
  21. #15
    Sep 2017
    Ashland city tn
    Yes its is a 2.5 , mine was 2.0. The 2.5 has a short skirt or notch on 1 side?. I think.? I'm not home to look ?
  1. head gasket and cylinder head
    By drtyTshrt in forum Technical Discussion
    Last Post: 03-26-2017, 08:47 PM
  2. OCD condition rears it's ugly head.... New Project?
    By Raceman in forum Other Motorsports
    Last Post: 12-05-2007, 11:18 AM
