Results 1 to 7 of 7
    Jul 2020
    VA
    quicksilver or sierra water pump kit?
    Would like to do a rebuild kit on my 96 2.5L Mercury 175. Seeing two kits available. One is quicksilver and the other is Sierra. Which is better? Also, it says the quicksilver kit (96148Q8) is for all short vane impellor motors 65HP-V6 how do I know if I have the short vane if I have nothing to compare it to? Is this the correct kit? Please forgive my ignorance, this is my first Merc.
    Sep 2017
    Ashland city tn
    Quicksilver/ merc is the oem kit. that's what u wanna try and use. Best thing to do is get on boats.net. look up ur motor and get the right part # then jump on Amazon and find that same kit little cheaper
  3. Thanks 1blueheron thanked for this post
    Mar 2015
    DFW
    I recently bought a couple sierra impellers to have as spares. I went to put one in a few weeks ago and it wouldn't even slide on the driveshaft, completely wrong dimension. Threw the other two away and re-ordered OEM. Impeller isn't worth it to save a few bucks.
  5. Thanks 1blueheron thanked for this post
    Likes nitro_rat liked this post
    Nov 2019
    Canada
    That looks like the number for the kit with the housing. You can also get them without housing if yours is in good shape.
    Kit with housing Quicksilver - 96148Q8
    Kit with housing Mercury - 96148A8
    Kit without housing Quicksilver - 89984Q5
    Kit without housing Mercury - 89984T5
    Blake
    www.InjectorService.com
    Call/Text - 204-326-0390
  7. Thanks Merc 2.5, 1blueheron thanked for this post
    Likes specboatops, 1blueheron liked this post
    Jul 2020
    VA
    Thanks for the replies. This will be a great help. Hoping to get it apart this weekend and see what I am dealing with.
    Gothenburg, Sweden
    Last time I heard, the Sierra impeller was exactly the same as the Mercury impeller. Made by the same machine.
    Mar 2015
    DFW
    Quote Originally Posted by Markus View Post
    the sierra I got the bushing material wasn't the same as the Merc. part and there was "casting flash" all over the actual impeller itself whereas the Merc. parts I ordered after I threw those away had none of that.
  1. Merc: would you use a Sierra water pump kit in a stock 2.0L v150?
    By pcrussell50 in forum General Boating Discussion
    Last Post: 05-26-2017, 10:19 PM
  2. Sierra water pump kit for 1995 2.5 Carb???
    By at100plus in forum Technical Discussion
    Last Post: 06-15-2016, 03:01 PM
  3. Sierra Fuel / Water Separator - Good - No Good?
    By bang2568 in forum Technical Discussion
    Last Post: 03-12-2008, 05:57 PM
