Results 1 to 5 of 5
    Sep 2008
    Delaware River,NJ
    Clear coat Lower Unit
    I primed and sprayed Etec with their Dark blue spray can.
    It came out pretty good but thought a light wet sand and clear coat would last longer.
    Would just any clear laquer spray can work?
    Any recomendations? They have a Rustoleum Acrylic Laquer at the auto store.
    It depends what kind of paint the "dark blue spray can" had in it?
    Note: Do not use Rust-Oleum Acrylic Lacquer over existing air-dried enamel paints.
    https://www.rustoleum.com/~/media/Di...cquer_TDS.ashx
    Sep 2017
    ontario
    i am not a big fan of spray bomb and it may peel - generally spraying lowers with out putting a good vynl wash primer to aid in adhesion then a good 2 part topcoat is preferred but you have started into it and yes you may be able to topcoat with a laquer spray bomb and get a decent short term answer - why not you have started why not finish but dont expect it to stay long .
    the above post is correct - you cannot spray laquer over enamel because the thinners in the top coat attacks the enamel and usually wrinkles unless sprayed very dry - orange peel finish and that is even difficult with a spray bomb
    Orange peel finish might be faster just sayin
    Sep 2008
    Delaware River,NJ
    Thanks everyone. I'll just stick with the Evinrude and no clearcoat. It came out good enough.
    OTE=kellytheaker;3223583]i am not a b
    the above post is correct - you cannot spray laquer over enamel because the thinners in the top coat attacks the enamel and usually wrinkles unless sprayed very dry - orange peel finish and that is even difficult with a spray bomb[/QUOTE]
  1. base coat clear coat WITH PEARL chameleon added
    By roadkill636 in forum Appearance Mods
    Last Post: 12-23-2015, 04:41 PM
  2. Real base coat / clear coat in a spray can results.
    By Mr. Demeanor in forum General Boating Discussion
    Last Post: 04-16-2012, 02:43 PM
  3. clear-coat ???
    By mer in forum Fiberglass and Composites Discussion
    Last Post: 04-24-2008, 09:45 PM
  4. Clear coat or gel coat on a 1989 Hydrostream HST?
    By Boz in forum Technical Discussion
    Last Post: 06-26-2003, 07:40 PM
  5. clear coat OR not to clear coat that is the question.
    By nitewolf in forum Fiberglass and Composites Discussion
    Last Post: 09-03-2002, 03:03 PM
