Results 1 to 15 of 15
    Dec 2006
    Chesterfield Twp, MI
    Looking for harder acceleration - (to 84.9mph) 5 Blade?
    I'm on the never ending search for "more acceleration" - The boats raced in class 4 OPA so I'm limited
    to 84.99, Yes the boat will pass the triple digit marks but in race water 85 is sketchy enough. So I'm
    I'm looking to find a good prop that pulls hard around and out of turns.
    I was spoke with a fishing guy and he said I should try a HIGH FIVE, They are not really a top speed
    prop, but they pull hard and handle well...
    What would (can) I expect from a High Five 25p.. suckers are small Dia. compared to my Hydromotive I'm
    running now.
ID:	470520Click image for larger version.
    Your slip will go down for sure but you need to have the torque to get there out of the turns. My guess is that your lap times will go down just from staying "hooked up" better do to more blade surface being in the water. You can buy a Drag five at a reasonable price for comparison testing.
  3. Likes Hayabusajm liked this post
    Celina, Ohio
    I had good luck with Merc Promax labbed props with all vent holes open. With vents plugged wouldn't come out of the hole worth a damn. Open it worked good. Once on plane acceleration was pretty good. I know over hub props( Drag 4) accelerated a lot better than an OT.
    We used to ski with a High Five... was like getting pulled by a tractor, it would rip your arms off from "Go boat!" but never ran one anywhere near 85 mph.
    Jul 2020
    Planet X
    Acceleration is mostly a factor of mass and power. You reduce weight or increase power then acceleration will increase.
    Acceleration doesn't really care if your slip is 5% or 20%, if your engine is in the power band it will propel the boat forward nonetheless. A prop with more bite can actually decrease acceleration since it takes the engine out of the high-end of the power band.
    You want a real change? Slap another engine on there..
    Dec 2006
    Well I lost some hardware and could not test the 25p prop...
    But I was able to tested my 31p prop - Not great water conditions
    and unusually heavy boat, pontoon and jet-ski traffic kept me from
    hanging it out to far.. but ran her up to 99.76 mph before I shut her down.
  8. Likes David - WI liked this post
    Quote Originally Posted by Pachanga_rick View Post
    running now.
    ...for acceleration improvement, the best money is spent on having the prop labbed, once you've found your best prop...
    Lake Coochiching, Ontario
    I wouldn’t expect the high 5 was designed to run anywhere near 85. If it were me I’d be looking at Drag 4/5, Promax or calling Hydromotive
    Oct 2009
    Gonzales, La
    I did acceleration testing using logged GPS and accelerometer data and found the number of blades didn’t appreciably change it. The pitch was clearly the chief factor. One of my tests was a 25” high 5, which hit my rev limiter at 75 mph.
    Dec 2006
    The Hi-Five did not really work, I'm guessing the dia was to small.. it did pull, but far to much slip.
    I'm going to try and prop down 1 size with the same Hydromotive prop I have now..
    Oct 2009
    Gonzales, La
    If you haven’t tried a promax, it would be worth it. I found it accelerated better on my boat than most others.
  14. #12
    Quote Originally Posted by kjiu78 View Post
    These things are getting to complex about the fishing as my canoe surfer did not work and I want to find anyone.But I was on trip and not found at that time or journey.
    ...More SPAM...SPAM...SPAM...
  15. #13
    Feb 2003
    Rochester, NY
    For those of you that believe we do not have a drug problem in this country, I rest my case.
    1992 Progression 22
    Mercury Racing 250R
  16. #14
    Celina, Ohio
    I think it sounds like Joe Biden
  17. Likes engineermike, FORBESAUTO, rgsauger liked this post
  18. #15
    It's just spam... "canoe surfer" is actually a hyperlink to another website. I reported him last week... must not be a big deal.
  1. what harder for marine tex
    By bill mason in forum Fiberglass and Composites Discussion
    Last Post: 12-27-2018, 07:26 AM
  2. Had to put my dog down......harder than I thought !!
    By specboatops in forum The Scream And Fly Lounge
    Last Post: 06-30-2016, 06:38 AM
  3. Replies: 89
    Last Post: 04-29-2015, 01:34 PM
  4. The Bigger They Are, The Harder They Fall?
    By Forkin' Crazy in forum The Scream And Fly Lounge
    Last Post: 11-15-2010, 12:34 AM
  5. 200 XS go harder.....
    By mercman13 in forum Technical Discussion
    Last Post: 01-26-2010, 04:03 PM
