Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 61 to 75 of 76
  1. #61
    Quote Originally Posted by mrcrsr View Post
    To elaborate
    Standard fire crank and chest layout ADI . Two triples (135)(246). Crankpin spacing within each triple 120°, crankpin spacing between both triples as firing order 60°. Distance from top of each triple to end of each tuner, effectively equal with standard ADI tuner(S), near one bore spacing difference +/- slightly different ratio adjustment.
    Carburation, one carb feeding two cylinders. One cylinder from each triple. Example top carb feeding cyl 1&2 , crank pin spacing 180° which is optimum but some overlap increases with high rpm (that's another issue). Each of the cylinders sharing a single carb have effectively the same exhaust tuning by length and tuner ratio. This enables a single carb to be in proper tune for each of cylinders. When a change to the tuner of one or both triples occurs as when using the T2 tuners each cylinder(s) in the pair then is not in proper tune with the carb. The effects of scavenging change are important to tuning through the rpm range. To add to it the setup is more prone then with defector heat with the changes. The carbs were tuned with some room for conditions of operation range and load for the exhaust and tuner as stock but it would be a risk to run it out of tune. When you experience the flat spot in the range it's showing this.
    The T2 set up has the triples layed out as (123)(456) with the firing order to compliment. Both triples still fall in near equal tune because of the tuner end difference as shown in the pic. The majority of the top triple's tuner is within the T2 chest itself. The total length of each triple to its tuner end is effectively equal again.
    I'd consider the c6 front for use on the ADI motor with standard fire order. Assembled with 6 intake runner divisions, add the Wiseco high domes and a bit of port work and slightly mod the stock adi tuner assembly. You'll have a c6 which runs like crazy with much better reliability and save the T2 and it's correct pieces.
    Build an adapter to accept the correct tuners to mod.
    Also consider the stock adi has the lower reed assembly with fewer petals than mid and upper assemblies to go along with slightly less duration than the previous years. It could be built to a real hot rod.
  2. Likes mrcrsr liked this post
  3. #62
    Maybe cut the tuner to more mimic the standard 115 tuner. My XS had no troubles turning that 30 cleaver past 6500
  4. Likes mrcrsr liked this post
  5. #63
    Jun 2004
    port st. lucie, fl
    I actually have a t2x powerhead for it, so I wouldn't cut the tuner, I'll have to make one for the adi engine
  6. #64
    ...thank-you for not cutting that rare piece... (i think the capt. lost his sanity there for a second, lol)
  7. Likes mrcrsr liked this post
  8. #65
    Just weld it back on
  9. #66
    Central, PA
    I love how this viper came out! Definitely the first time I've ever seen a 12" mid on a stream
  10. Likes mrcrsr liked this post
  11. #67
    Dec 2001
    I ran a 150 merc on a T2 housing.....Just add some pipe to the short one. Than same as 115 Adi motors. Adi 90 HP had low ports but used the 150 meggaphone..... go figgua....115 had long straight ones....Are ya using the ing ady box? What reeds....150 banjos?
  12. #68
    Jun 2004
    port st. lucie, fl
    Adi 115 is a bone stock low hour engine, it ran 76 mph yesterday, at 6200 rpm, with a 14.5 30 Merc lab cleaverClick image for larger version.
  13. Likes FUJIMO liked this post
  14. #69
    Pretty sure I was about 11\2 above with a 30 4 blade humpback on the vector. Hole shot sucked but would run 81. Was looking at the 2 1\2 t2 powerheads the other night after reading this thread. Maybe in a couple years after I fry some other fish on the table.
  15. Likes mrcrsr liked this post
  16. #70
    May 2014
    WI
    So this boat will have hydraulic steering, but wanted to be able to use the original rideguide wheel. My friend Tyler from muscleboats actually had a brand new rideguide wheel, with the original decal, so I adapted the rideguide wheel to fit the seastar hydraulic helmAttachment 470172Attachment 470173Attachment 470174
    This is really cool. Any chance you have more pictures of what all you had to modify for it to work?
  17. #71
    ...first known T2x/1750xs/T-3 clamp bracket known to have been rigged on a viper, circa 1977... ran well.
  18. Thanks Mad Maximillion thanked for this post
    Likes Michael J Giesler, Capt.Insane-o liked this post
  19. #72
    SOCAL
    Wow...a blast from the past! “Mothers Worry” That was Sammy’s Viper in front of Action Marine in Dearborn Mi. I was in that boat with Sammy on the Detroit river...109mph on the Keller!
  20. Likes FMP, Capt.Insane-o liked this post
  21. #73
    ...glad to see you got out of the great white north years ago mike...
  22. #74
    Hey Mike
  23. #75
    Jun 2004
    port st. lucie, fl
    Picked up some new stuff for the hydrostreamClick image for larger version.
  24. Likes LakeFever liked this post
  1. 1976 Hydrostream Viper: Code name "Swiss Cheese"
    By '82 Vector in forum Fiberglass and Composites Discussion
    Last Post: 04-19-2015, 08:26 AM
  2. Replies: 0
    Last Post: 09-11-2013, 02:29 AM
  3. "Brand New" Never Rigged 1988 Hydrostream Viper
    By mragu in forum General Boating Discussion
    Last Post: 03-03-2008, 03:28 PM
  4. Black Comp Viper "Team Hydrostream"
    By wireless in forum General Boating Discussion
    Last Post: 02-24-2008, 02:49 PM
