Page 1 of 6 1 2 3 4 5 6 LastLast
Results 1 to 15 of 76
    Jun 2004
    port st. lucie, fl
    Hydrostream viper 12" mid build, with t2x and v6 power
    Greg has been asking me for awhile to put up some pics of the new build I'm doing, 1978 hydrostream viper, apricot boat. I recored the boat using divinicel, and a mix of carbon fiber and 1708, with epoxy. Click image for larger version.
ID:	470162Click image for larger version.
ID:	470163Click image for larger version.
  2. Likes 89LASER, tnelsmn, kyja95 liked this post
    Jun 2004
    port st. lucie, fl
    So the original gel clear was bad on the boat, someone shot automotive clear on it making it even more difficult to fix. West Marine sells a paint stripper that is gel coat safe, basically apply it, let it sit, and use a plastic scraper to remove it. Worked well. Then I washed the whole boat, scuffed it with a scotchbrite pad, and reshot it in awlcraft clearClick image for larger version.
ID:	470165Click image for larger version.
ID:	470166Click image for larger version.
ID:	470167Click image for larger version.
  4. Likes 89LASER, delawarerick, tnelsmn liked this post
  5. #3
    Jun 2004
    port st. lucie, fl
    And reclearedClick image for larger version.
ID:	470169Click image for larger version.
ID:	470170Click image for larger version.
    Jun 2018
    Floating around
    Thank you Greg for suggesting this and mrcrsr for posting up. I really dig seeing these resto threads and I wish I knew about that stripper last year
  7. Likes mrcrsr liked this post
    Jun 2004
    port st. lucie, fl
    So this boat will have hydraulic steering, but wanted to be able to use the original rideguide wheel. My friend Tyler from muscleboats actually had a brand new rideguide wheel, with the original decal, so I adapted the rideguide wheel to fit the seastar hydraulic helmClick image for larger version.
ID:	470172Click image for larger version.
ID:	470173Click image for larger version.
    Jun 2004
    port st. lucie, fl
    So I picked up a t2x for the hydrostream, supposedly made 180-200 hp. Crankshaft was damaged, so I sent it out to have it repaired. Currently everything is cleaned and painted, had to bore 2 cylinders oversize in it, and was able to find a couple of nos 1350 pistons for it, as they don't have the scallop on the crown. Just need the time to assemble it. I'll keep updating this post as I have time, have a bunch more pics of everything that had to be machined and made. Click image for larger version.
ID:	470176Click image for larger version.
ID:	470177Click image for larger version.
  10. Likes 89LASER liked this post
  11. #7
    Jun 2004
    port st. lucie, fl
  12. #8
    Wow, picked up a T2X. That's beautiful
  13. Likes mrcrsr liked this post
  14. #9
    Jun 2004
    port st. lucie, fl
    Originally I was just going to run an adi 115, and the t2x, so I picked up an inline 15" mid. Original tiller arm wouldn't clear the bottom carb on the t2x, and I didn't want the old style external trim rams down either side, and I wanted seastar pro steering. So I picked up a 3 cylinder Merc integral power trim clamp bracket, and basically mated the 15" midsection to the integral bracket, and made up a new tiller arm that cleared the bottom carb, and allowed the use of hydraulic steering. That whole project is done, then I came across the 12" midClick image for larger version.
ID:	470187Click image for larger version.
ID:	470188Click image for larger version.
ID:	470189Click image for larger version.
ID:	470190Click image for larger version.
  15. Likes Capt.Insane-o, 89LASER liked this post
  16. #10
    Jul 2004
    Fort Lauderdale, Florida
    That gel came back beautifully, Charlie--looks great!
    Per Rock:
    "Once I bought my first Hydrostream boating changed forever for me."
    Per my hero Instigator:
    "I try not to let common sense interfere w/my boat buying decisions."
    Pat Gent
    cell 954-249-3246
    '78 Hydrostream Vandal (being rebuilt)
    '86 21' Eliminator Daytona, 300 OMC V-8 (Li'l Toy III)
  17. Likes mrcrsr, Capt.Insane-o, LakeFever liked this post
  18. #11
    How's the tuner setup, still 3 bore spacing difference between both ends in that leg?
  19. #12
    Mar 2016
    cincinnati, ohio
    In the first post you show the seat mount, how are you going to mount the seats, any access to tighten nuts or what???? Thanks
  20. #13
    Jun 2004
    port st. lucie, fl
    Quote Originally Posted by Li'l Toy View Post
    Thanks pat, I've been chipping away at it for the past 2 years, only way it's going to get done is if I come up with a boat run I want to take it to. I'm thinking the November Suwannee run should be it. Work and life always gets in the way. How is the eliminator coming along?
  21. #14
    Jun 2004
    port st. lucie, fl
    Attachment 470212 so these are generic pics I have in my phone, but I have a t2x tuner/adapter and an f1 tuner for the v6 part. I basically would've made my own tuner for the 15" project
  22. #15
    Jun 2004
    port st. lucie, fl
    Quote Originally Posted by 1954bmw View Post
    So I marked on the seat bench where my holes come through, drilled it out with a 2" holesaw in the bench, taped the bottom closed, and filled the holes with a blended mix of epoxy and chopped fibers.
  1. 1976 Hydrostream Viper: Code name "Swiss Cheese"
    By '82 Vector in forum Fiberglass and Composites Discussion
    Last Post: 04-19-2015, 08:26 AM
  2. Replies: 0
    Last Post: 09-11-2013, 02:29 AM
  3. "Brand New" Never Rigged 1988 Hydrostream Viper
    By mragu in forum General Boating Discussion
    Last Post: 03-03-2008, 03:28 PM
  4. Black Comp Viper "Team Hydrostream"
    By wireless in forum General Boating Discussion
    Last Post: 02-24-2008, 02:49 PM
