Results 1 to 5 of 5
    Jul 2020
    Maryland
    Questions. 1992 gambler. 200 merc
    I have an opportunity to purchase a 92 gambler and I believe same year motor. I don’t have much knowledge on this combination other than gamblers reputation for speed. Test drove the boat by myself topped at 63mph at 6k rpms with 25 pitch 3 blade prop. Motor is still factory and compression cold is between 118-120 for all cylinders. Still has original oil set up. What can I expect to achieve out of this boat speed wise with modifications? What would be some recommendations? What would the value be on this set up? Has original trailer in good condition. All factory electronics work. No depth finders.
    my goal is to to get back in a bass boat and break 70. I have owned two skeeter’s in the past with yamaha’s and have been out of the game for 10 years. The idea of this boat has ignited an old flame. I am trying to determine if this is the one for me or if I should keep on Looking.
    Attached Thumbnails Attached Thumbnails CE767FBD-38FB-4313-BAA6-7D83CDF6305F.png
    Jul 2020
    Maryland
    TX......somewhere?
    look for a 20xd bullet.....
    Houston, TX
    Check out the gambler forums on bass boat central.
    Houston, TX
    70 is a reasonable goal
  1. 1992 150 XRI voltage regulator questions
    By gpxsrxracer in forum Technical Discussion
    Last Post: 05-17-2019, 03:17 PM
  2. 1989 Gambler 206cc 1998 merc 175 EFI setup and hull design question
    By mjpowersports in forum Props, Setup, and Rigging
    Last Post: 10-28-2014, 06:42 PM
  3. OMC Tech: 1992 115hp Crossflow questions, RPM, heads
    By RoyE in forum Technical Discussion
    Last Post: 07-04-2013, 12:04 AM
  4. 1992 XP200 Questions?
    By Billyboy21 in forum Technical Discussion
    Last Post: 07-20-2007, 01:29 AM
