Results 1 to 9 of 9
07-22-2020, 12:41 PM #1Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
09 225 opti has low voltage fault code
Getting a sensor supply voltage low B code #602-5 From what I have read the pcm is possibly faulty in sending out the 5v to the sensors. I have another pcm to swap but don't want to swap out if there is a possibility of sending another one to the trash pile. Any advice? Batt and wires good.
07-22-2020, 12:45 PM #2
Can you put your pcm on another Opti and see if you get the code? Otherwise Simon/Brucato/Powers must test PCM's?
07-22-2020, 12:51 PM #3Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
Yes, I can swap pcm's but am wary to do it thinking the engine may have a problem that could fry the second pcm too.
07-22-2020, 12:52 PM #4
07-22-2020, 01:14 PM #5Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
You are right... I might give it a try. Thanks for the guidance....
07-22-2020, 04:52 PM #6Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
What's the procedure to check voltage going to the sensors? Google was no help.....
07-22-2020, 06:11 PM #7
Is this your motor? https://www.google.com/url?sa=t&sour...512YsKi8Ixd7jO
Looks like maybe not, sorry.Last edited by David - WI; 07-23-2020 at 12:04 AM.
XstreamVking thanked for this post
07-22-2020, 06:47 PM #8Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
Mines a down draft...Ser. no 1B780484 09 225 opti. I may just bite the bullet and take it to the dealer to be scanned. Lot of variables. Could be a sensor, or computer, or I dunno....Had a long beep and went into guardian mode when trying to 1st plane it out. Shut it off, re-started it and ran all day with no issues or beeps. I have a merc monitor that reads on my phone and gave the code and problem.
07-27-2020, 05:26 PM #9Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
I sleuthed it down to the trim sensor being the culprit. Pulled it and all's well. Did the trick of swapping the pcm and found it to be good. Darn opti's are the strangest engines....
dgscroggs, David - WI liked this post
Mercury Tech: 300 xs fault code 110
By naples39 in forum Technical DiscussionReplies: 1Last Post: 07-19-2015, 01:33 PM -
300xs fault code.
By Turborr in forum Technical DiscussionReplies: 3Last Post: 12-08-2014, 09:58 PM -
Fault code 94 pitot ckt lo
By KEVIN P in forum Technical DiscussionReplies: 5Last Post: 08-08-2013, 06:18 AM -
Mercury Tech: 91-2.5 200HP EFI, fault code reader?
By 4JawChuck in forum Technical DiscussionReplies: 0Last Post: 11-01-2009, 02:53 PM -
FAULT CODE ON 300x'S
By SIESTASTREAMN in forum Technical DiscussionReplies: 0Last Post: 06-05-2002, 03:38 PM
