Results 1 to 9 of 9
07-17-2020, 09:10 AM #15000 RPM
- Mar 2012
- Lake Hopatcong, NJ
- 218
- 31
2.5 280 that floods during starting
I have a 280 that doesn't like to start. When it's cold it will start no problem, but once it's warmed up and you try to start in gear, it will flood out often. It's a 50/50 guess as to whether or not it will fire, which can get interesting around docks with a motor that can't be shifted while running. Once it floods, I have to shut off the fuel pump and fire it to clear it out. Then it starts fine. Injectors have been services by Brucato, and I also swapped another set as a test, same issue. All air passages in the horn have been cleaned, all sensor readings are good, rings and reeds are new, compression is good. Once up to speed the motor runs great all the way up to redline, but it does have a decent surge that happens in no wake zones around 3000 rpms.
Also, this is a 280 powerhead on an offshore mid from a 1993 260. Not sure if that could have something to do with it? It's been this way since I put the fresh powerhead on this mid. I mention this because the motor whistles air out of the horn as the boat goes up and down with waves. Seems weird that the water rising in the mid pushes all the way up into the motor, but maybe that's just the way they are?
07-17-2020, 09:28 AM #2
I had a similar issue but mine was laser injection not a horn motor. I had a couple broken reeds.
But you say your reeds are new.
07-17-2020, 09:52 AM #3
I shifted my 280 for 10 years and never had issues May want to check airgap when throttle is closed... been a long time but think it's .004
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
07-17-2020, 02:39 PM #45000 RPM
- Mar 2012
- 218
- 31
07-17-2020, 03:01 PM #55000 RPM
- Sep 2017
- ontario
- 716
- 68
- 43
- 73
- 171
If DDT is avalable - check to see where FUEL OFFSET is - i wonder if your + 1 on that setting . Possibly if you go "0" on the setting it may improve your idle characteristics . Check the plug as well for stock setting and of course the plug type - stock - can' recollect the change . So fuel offset and plugs- 2 simple items . From what I know - Little - Fuel offset can be adjusted + 1 , 0 , or - 1 . From DDT . Hope that helps
07-18-2020, 07:39 AM #65000 RPM
- Mar 2012
- 218
- 31
Thanks. I have a Rinda tool that can read all the sensors but it doesn't look like it has that fuel offset function. Will try to find someone with a DDT. I've also replaced the plugs a few times over the last year that this has been happening, but that hasn't helped. Tried both the stock Champions and NGKs. Same problem.
I'm thinking that the starting problem is somehow related to the surging that I get at 3000 rpm.Last edited by tripower; 07-18-2020 at 07:42 AM.
07-18-2020, 09:00 AM #75000 RPM
- Sep 2017
- ontario
- 716
- 68
- 43
- 73
- 171
Rhinda - im not all that familiar with the tool but suspect it will possibly look at that parameter , do you need to page down further to get to that setting or do you have a rhinda manual that walks you into window or features . I am personally only proficient on the DDT from OTC . call them and see if you can get the skinny from a tech at rhinda - this may be just that fuel setting - possibly too rich for your area/sea level - at least check - its sometimes just the simple stuff - if you skip a simple check you may run around in circles . i have read threads of the 280 loading up a touch at prolonged idle stints. As well I had read a thread of the disconnect the fuel pump to clear it'self and then fires - was that an earlier thread of your motor and running condition .
Let us know if Rhinda was capable of changing fuel setting . Should I would hope .Last edited by kellytheaker; 07-20-2020 at 11:02 AM.
07-21-2020, 06:04 PM #8
put a kill switch on the high pressure fuel pump to kill the pump when hot starting its a common 280 thing
07-22-2020, 04:15 PM #9
OMC Tech: johnson 85 1975 floods when throttled
By toplesshorse in forum Technical DiscussionReplies: 2Last Post: 05-01-2011, 09:07 PM -
Iowa Floods! Here's a link for pictures.
By ssent in forum The Scream And Fly LoungeReplies: 1Last Post: 06-19-2008, 04:57 PM -
how florida residents drive in floods
By godspeed in forum The Scream And Fly LoungeReplies: 14Last Post: 09-28-2006, 07:53 PM -
Starting Nov. 3rd
By INXS in forum The Scream And Fly LoungeReplies: 2Last Post: 09-18-2004, 03:22 PM -
2.4 BP EFI floods & shuts down
By Danno in forum Technical DiscussionReplies: 1Last Post: 06-05-2001, 09:30 PM
