Results 1 to 15 of 18
07-15-2020, 05:02 PM #1Junior Member
- Jul 2020
- lebanon
1978 avenger 17' with 200 merc want to go faster
just bought this boat and it has a 17 pitch stainless prop but will only go 45 mph can and should it go faster
07-15-2020, 05:20 PM #2
yes it should be in the 60's easy. post up some pictures, great boats.
07-16-2020, 12:11 PM #3Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
I know nothing about your boat, but I had a 78 or 79 invader with a same year inline 6 115 on it with a 17p aluminum prop and I was running maybe 40 mph or so. My boat was a deep v heavy old tub. Floor was soaked, core probably was too.
So yeah, you have a ways to go with your set-up. You should moving a bit faster then what you are.Especially if this is close to what you have:
07-17-2020, 09:40 PM #4Junior Member
- Jul 2020
- lebanon
07-18-2020, 06:33 AM #5
Nice looking Avenger, wonder if set back with a jack plate would help with that. The motor has been gone thru? Hull not wet? Firing on all cylinders?? 45 seems awfully slow for that boat. Where are you located?
07-18-2020, 06:59 AM #6
17 pitch and 17ft boat the rpm has gotta be thru the roof at wot? Need find u a 24 or 25 I would think
David - WI liked this post
07-18-2020, 07:34 AM #76000 RPM
- Aug 2015
- Southeast
- 1,067
- 134
- 79
- 48
- 614
Absolutely. You're running around stuck in 2nd gear. Get some more pitch. I'd think you could pull a 26 pitch prop. Will slow down your hole shot and acceleration but cruise and top end will be much better. Not sure what the WOT rpm target is on your motor but id guess mid 6k range. You want as much pitch as your motor will pull and still be able to hit the targeted rpm on top. Other considerations need to he addressed also, but 17 pitch is for a big heavy boat or slow underpowered boats.
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship"
Blazer 650 Pro Tour
Merc 2.5 liked this post
07-18-2020, 08:32 AM #8
My bass rig is on heavy side 19.5ft , I run a modified 25 (runs more like 26) and it's my everything prop , I can put 2 more people and gear and still hit target rpm , u dont wanna max out ur motor/prop for 1 person , cause when u add a person or 2 it will bring rpm down and u still wanna be able to get to the 5800 range atleast. I'm around 6300 ish with just me and 5800 5900 with people ,coolers, etc. My 28 chopper is perfect with just me but when I add 1 other person it's to much. Hope that helps some. Also need just double check fire and fuel and make sure everything up to par. Good luck
07-20-2020, 08:01 AM #9Junior Member
- Jul 2020
- lebanon
i no nothing about the boat im in Lebanon Oregon i bought it and it was not running got it to fire on all cylinders and installed a new water pump impeller
07-20-2020, 08:10 AM #10Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
Well, you are headed in the right direction. Now you just need to find the right prop and motor height, maybe even a little set back.
07-27-2020, 02:48 PM #117000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
what is the width of the pad if it has one. without a pad 60mph is your limit, it will chime walk.
a boat like that with a 200 should go 65-74mph with a 8" setback and a jack plate at 1" below the bottom the rpm should be around 6200. that should be your rpm limit with stock oil mixing. the plastic gears are the issue with the pump. it should have steel races on crank bearing so with mixed gas 7000 is ok.
07-28-2020, 10:03 AM #12Junior Member
- Jul 2020
- lebanon
cool thanks changed the prop last night from a 17 pitch to a 25 pitch didn't really change much
07-28-2020, 10:08 AM #136000 RPM
- Aug 2015
- Southeast
- 1,067
- 134
- 79
- 48
- 614
Blazer 650 Pro Tour
07-28-2020, 10:12 AM #14
Or it's trimmed "full down" the whole time.
07-28-2020, 10:23 AM #156000 RPM
- Aug 2015
- Southeast
- 1,067
- 134
- 79
- 48
- 614
Blazer 650 Pro Tour
mercury trim pumps- looking for a faster merc pump
By mrcrsr in forum Technical DiscussionReplies: 9Last Post: 03-04-2010, 06:50 AM -
whats faster 140 omc or 115 merc
By MJ POWERSPORTZ in forum General Boating DiscussionReplies: 25Last Post: 10-07-2009, 07:52 AM -
Merc 135hp! make it faster???
By mattboy in forum Technical DiscussionReplies: 4Last Post: 09-28-2009, 11:47 PM -
1978 Merc V6 150
By MISSING in forum Technical DiscussionReplies: 1Last Post: 04-09-2008, 08:59 AM -
225 merc on my 15 Bee Bee Avenger
By KG4 in forum General Boating DiscussionReplies: 3Last Post: 11-17-2002, 09:20 AM
