Results 1 to 6 of 6
Thread: 2.5 260 runs then dies out
07-14-2020, 06:07 PM #1Member
- Aug 2008
- pa
- 77
I have a 260 efi horn motor. Fires up runs then dies Crank it and it fires right back up. If I put it in gear it dies instantly I just ran it a few weeks ago and noticed when idling in gear it seemed to be loading up by when I would take off it cleared up and ran great. Today I couldn’t even get it to run in gear. Batteries are new and fully charged, fuel pump and filter are brand new as well. Could it be the ACU ?
07-15-2020, 08:21 PM #2
Put a fuel pressure gauge on it to verify it's maintaining proper fuel pressure.
07-15-2020, 08:37 PM #35000 RPM
- Apr 2007
- Big Pine Key, Fl
- 414
- 13
- 21
- 45
- 107
07-16-2020, 05:03 AM #4Bud Conner "Heathen" "Defending Our Constitution"
07-16-2020, 05:10 AM #5Member
- Aug 2008
- pa
- 77
I just cleaned the map sensor fitting in the air horn and checked the map sensor itself, It’s definitely not a fuel pressure related issue it just cuts out. I tested the stator as well and that’s all good. I have a bad feeling it’s the ecu. I’m going to send it out to Brucato to have them test it
08-03-2020, 03:31 PM #6Member
- Aug 2008
- pa
- 77
Update. Sent my ecu to Brucato and the fuel pump driver is bad. So I ordered a new Brucato ACU
Mercury Tech: 1980 Merc 2.4 runs on 4 or 5 cyl cold, runs on all 6 warm
By mklein in forum Technical DiscussionReplies: 2Last Post: 07-06-2016, 01:53 PM -
1996 johnson 225 ocean pro Runs ?? then dies
By 1fastg3 in forum Technical DiscussionReplies: 12Last Post: 09-12-2011, 08:12 PM -
2.5 EFI - runs but dies at speed???
By maverick1 in forum Technical DiscussionReplies: 6Last Post: 07-07-2006, 08:17 PM -
2.5 efi runs 1 minute then dies
By jwcangemi in forum Technical DiscussionReplies: 5Last Post: 07-17-2001, 08:06 AM
