Results 1 to 6 of 6
    pa
    2.5 260 runs then dies out
    I have a 260 efi horn motor. Fires up runs then dies Crank it and it fires right back up. If I put it in gear it dies instantly I just ran it a few weeks ago and noticed when idling in gear it seemed to be loading up by when I would take off it cleared up and ran great. Today I couldn’t even get it to run in gear. Batteries are new and fully charged, fuel pump and filter are brand new as well. Could it be the ACU ?
    Ft. Lauderdale, Fl
    Put a fuel pressure gauge on it to verify it's maintaining proper fuel pressure.
    Apr 2007
    Big Pine Key, Fl
    Quote Originally Posted by flabum1017 View Post
    Check your vac port
    that runs from your air horn to your ECU.some times the vac port is clogged and the ECU is not getting the map signal....runs rich
    Ed I need your email address again so i can send you those Classes and Rules we were talking about yesterday.. Ive lost it
    Quote Originally Posted by laser_ED View Post
    Check your vac port
    pa
    I just cleaned the map sensor fitting in the air horn and checked the map sensor itself, It’s definitely not a fuel pressure related issue it just cuts out. I tested the stator as well and that’s all good. I have a bad feeling it’s the ecu. I’m going to send it out to Brucato to have them test it
    pa
    Update. Sent my ecu to Brucato and the fuel pump driver is bad. So I ordered a new Brucato ACU ��
  1. Mercury Tech: 1980 Merc 2.4 runs on 4 or 5 cyl cold, runs on all 6 warm
    By mklein in forum Technical Discussion
    Last Post: 07-06-2016, 01:53 PM
  2. 1996 johnson 225 ocean pro Runs ?? then dies
    By 1fastg3 in forum Technical Discussion
    Last Post: 09-12-2011, 08:12 PM
  3. 2.5 EFI - runs but dies at speed???
    By maverick1 in forum Technical Discussion
    Last Post: 07-07-2006, 08:17 PM
  4. 2.5 efi runs 1 minute then dies
    By jwcangemi in forum Technical Discussion
    Last Post: 07-17-2001, 08:06 AM
