Results 1 to 1 of 1
    Jun 2009
    central minnesota
    200 merc efi start no run
    2001 merc 200 efi, had antisiphon valve plugged-fixed.cleaned all supply lines,new primer bulb,lift pump diaphram kit,new spin on filter on motor.no voltage to hi press pump at negative term(fuel pump driver out) corrected by installing relay fired from purple wire(with key on).now have 35#+ pressure at shrader valve with key on.key off pressure drops to 30# and stays there for hours. turn key- starts and runs for 2 to 4 seconds and dies.fuel pressure stays 35#+.starts over and over but will not stay running. all help will be appreaciated-th
  1. Yamaha Tech: Question about adding recoil start on an electric start 9.9 Yamaha - can it be done?
    By Steve2ManyBoats in forum Technical Discussion
    Last Post: 09-11-2012, 06:12 AM
  2. merc 2.5L xr6 won't start
    By cbigcarl in forum Technical Discussion
    Last Post: 09-05-2009, 08:00 PM
  3. Merc 2.5 260 efi no start help!!
    By pilotgmb in forum Technical Discussion
    Last Post: 08-15-2007, 05:15 AM
  4. 99 merc 2.5 EFI SS hot no start
    By new2allison in forum Technical Discussion
    Last Post: 09-03-2004, 01:19 PM
  5. Why won't my Merc start??
    By zmoz in forum Technical Discussion
    Last Post: 08-09-2003, 03:49 PM
