Results 1 to 8 of 8
Thread: WTB 225 Promax ECU
07-12-2020, 09:10 PM #1
WTB 225 Promax ECU
Looking for a clean 99 model ecu for a 225 promax. Just looking and comparing. Let me know what you have and how much. Thanks
Respect no wake zones!!! Evinrude guys need a place to race too.
07-13-2020, 04:34 AM #2
So you must be looking for an A32 and what are you comparing?
Keep in mind that what ever you find if they do not have or know history could have been work by someone like Simon, Hoffman even Mercury so there is a chance they will not match.
The main goal is that is in good working order through all perimeters, I personally test all mine.
07-13-2020, 10:53 AM #35000 RPM
- Apr 2007
- Big Pine Key, Fl
- 416
- 13
- 21
- 45
- 109
07-13-2020, 03:03 PM #4
He has the A32 now and it was re flashed, We think it was re flashed really fat as it loses its kahones around 5800rpms where it should be gaining. I will tell him, he may want a swing at the A17, his ecu is at Bracato right now for a full 100% rundown. Will say this, my buddy doesn't try to save money on his Merc, he shoots for the top end guys.
07-13-2020, 03:43 PM #5
Where does the A6 fall into the LEANvsRICH curve?
07-15-2020, 12:04 PM #6
Ok, so the other ecu tested bad at Brocado, fuel injection and fuel pump readings were very abnormal. He is looking for a completely stock A32. Prices and offers?
07-15-2020, 01:10 PM #75000 RPM
- Apr 2007
- Big Pine Key, Fl
- 416
- 13
- 21
- 45
- 109
.....Ok,,both of the ECUS that I have are stock mercury ,they have never been reprogramed by anybody..The A17 was the 1st generation 225 promax ECU,mercury decided that it was to lean from about 4000 to 5000 rpms and it was causing engine failures on heaver and higher pitched rigs....Mercury offered to reflash the A17 to gen 2 A32 which had more fuel in lean spots...I like the A17 on lighter rigs,they accelerate harder,and if you have an adjustable
regulator you can tune it..to a degree...Ed
07-15-2020, 02:18 PM #8New Member
- Oct 2019
- Knoxville, tn
Ed, thanks. Im the one that TnRoostertail made the post for. Didn't realize I already had an account here. Lol. I will be in touch with you by the weekend about an ecu if I can't source a good one locally that won't need shipped. It will be the a32. Its going on a 21ft Gambler and is not what I would call lighter. 1650 dry weight, we are estimating 2700lbs rigged to fish. Everything is stock on the motor, and if this solves my possible lack of power, I will be spending some time around the 5k mark, so I'd rather not chance the a17 or even an a06 ecu.
Thanks Ed.
WTB 300X or Promax cowl, side ram for offshore Promax mid, Sportmaster internals
By bayratpg in forum Parts WantedReplies: 0Last Post: 04-06-2016, 09:49 PM -
Mercury ProMax 225 vs ProMax 225X. What are the differences?
By stv1991 in forum Technical DiscussionReplies: 1Last Post: 09-08-2012, 06:20 AM -
Top speed gain Promax 300X over Promax 300
By Toffen in forum General Boating DiscussionReplies: 1Last Post: 02-08-2004, 05:19 PM
