Results 1 to 12 of 12
    Jun 2020
    southeast GA
    water pump problems
    i have water coming out only right side of motor 93 2.5l 280hp it does not feel like its getting hot on that side vs the other. im new to these motors so im trying to learn them. its a new pump only few hours on it if it stopped up where do i look for blockage? it was pumping fine while running at speed.
    Jan 2015
    When you say water coming out of side of motor, where exactly do you mean? The lower unit, the mid section or the power head?
    All of my motors had some coming out of the side of the lower unit. Always just considered it normal.
    Jun 2020
    southeast GA
    Quote Originally Posted by SS Minnow View Post
    there are 2 pee hole lines on this motor only coming out right side
    Jan 2015
    Quote Originally Posted by tangerine386 View Post
    What part of the motor? If not sure, snap a picture showing it or where you can point it out.
    If it is in the lower unit, probably no big deal. In the mid, probably a problem. If it is in the power head, definitely a problem.
    Jun 2020
    southeast GA
    280 with a poppet?????
  7. Thanks tangerine386 thanked for this post
    Jun 2020
    southeast GA
    what is a poppet? [t has a two hole lower
  9. #8
    Aug 2002
    waterloo IN
    Put your finger over the end of the hose it most likely will come out the outer side. My drag does the same thing at idle. Plane it off and i bet water squirts out both sides. That used to bother me too but it has done it 19 years and not hurt anything. The poppet is under the cover of the hose that is peeing. The water is just taking the easy way out. Thought about plugging the poppet cover and draining both heads off the thermostat housings like my old 2.4 but i was told to leave it alone.
  10. Thanks tangerine386 thanked for this post
    Aug 2002
    waterloo IN
    Be careful running in a tub like that. I cooked a water pump doing that. The water level was below the impeller and it melted before it pulled it up. Make sure the water is as high as the impeller
  12. Thanks tangerine386 thanked for this post
    Jun 2020
    southeast GA
    ok thanks for info i dont run it long in the tub and i shoot water in the impeller. when i noticed it in the lake at idle i was having fuel issues so i didnt go back out to run it. just replaced fuel pump and regulator and she sounds better and crankin easier now thats why i had her in the tub i have a attachment for the nose cone would it help to put it on while in the tub?
  14. #11
    Aug 2002
    waterloo IN
    If you have the muffs, garden hose attachment for the lower unit i would use that. It will force water to the impeller. Once you get moving at h high idle i think you will see water coming out both sides.
  15. Thanks tangerine386 thanked for this post
  16. #12
    Jun 2020
    southeast GA
    thanks WB will try it that way next.got to install my switch to fuel pump and i will crank her again.
  1. Replies: 54
    Last Post: 09-23-2019, 11:00 AM
  2. Mercury Tech: 89 200HP Mariner Low Water Pressure - water pump and hoses flow fine
    By tristanlee85 in forum Technical Discussion
    Last Post: 07-02-2018, 10:59 PM
  3. 300 Pro Max water problems
    By motexas in forum Technical Discussion
    Last Post: 09-06-2002, 09:17 AM
