Results 1 to 15 of 25
Thread: 3m 5200
    May 2020
    3m 5200
    How do you guys feel about bedding stringers and knees to the hull with 3M 5200? Then follow up with glassing in after the 5200 is cured. I’m almost to this stage in my Ventura build and have 2 tubes of 5200 caulk gun size tubes.
    Jun 2018
    Floating around
    That’s what I’m planning to do
    May 2020
    Me too...
    Jun 2018
    Floating around
    I thought I posted about this in Tnels thread but I can’t seem to find it. There is discussion about setting the stringers in 5200 though. I did some homework on this a while back and a very reputable hydrostream builder uses 5200 to set the stringers. As I understand it most of the strength comes from the glass not the wood.
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    Use it on anything you never want to get it off of it's great adhesive. But let it cure fully before you encapsulate it.
    Jul 2012
    Lufkin, Texas
    i bedded the base for the bilge pump in my jon boat in 5200, figured it was better than screwing it through the bottom. Holding up fine so far...
  7. Likes Laseraddict liked this post
    Aug 2006
    Wilmington Delaware
    Used it today, how do you get it out of your hair? LOL
  9. Likes nitro_rat, Merc 2.5 liked this post
    Dec 2017
    We used to call it 5200 for how many hours it took to wear off of your hands, knees, and feet.
    For hair the little woman says scissors
    Sep 2012
    Just curious...for something so important (to me) why don't you use west system epoxy that is tried and true?
    Minneapolis MN
    Thats how I did mine. Was recommend to me from my material supplier. I let it set up in a warm garage for a few days before glassing over it. I'm not pro, so take it with a grain of salt.
    Houston, TX
    Epoxy and wood flour make peanut butter. That's what I used and it worked great. Also works perfect for making your fillets at the square edges. 4" fiberglass tape is your friend.
  14. #12
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by Turborr View Post
    For epoxy West is overpriced. If you have $$$ to burn...
    If the final layup is poly or vinyl resin those won't stick to epoxy. However you do it, it all has to work together...
  15. Thanks Laseraddict thanked for this post
    Likes tnelsmn, Laseraddict liked this post
  16. #13
    Houston, TX
    Agree with Nitro Rat. I used System Three "silver tip" 2:1 epoxy. It worked great, wet out nicely, good stuff. Bought all my supplies from boat builder central.com
  17. Likes Laseraddict liked this post
  18. #14
    What is the advantage of using 5200 for a bedding material?
    May 2020
    not sure on the advantage/disadvantage. I know some do it some don’t, I am now one of those guys that used the stuff. I will say it allowed me more time to manipulate my knees and stringers to exactly where I wanted them, I could even come back the next day and move things just a tad if things moved a bit. I’m relying on the strength for my knees and stringers to come from glassing them in to the hull not the 5200. The 5200 says it needs 7 days to fully cure, I knew when I set my stringers and knees into it I was done working on the boat for a week anyway, I let it set for the full 7 days. If a guy is in a rush to keep working 5200 is not the thing to use. Don’t know if this answers your question or not, I’m by no means a expert. I learn as I go.
  1. 79 vector $5200
    By nelson edens in forum Ebay Listings and Other Internet Listings
    Last Post: 09-02-2018, 06:48 AM
  2. 5200 all over the place.
    By 83PREDICTOR in forum The Scream And Fly Lounge
    Last Post: 05-12-2012, 06:03 AM
  3. How to get off 3M 5200??
    By skydog in forum Fiberglass and Composites Discussion
    Last Post: 04-14-2004, 04:24 PM
  4. How to get off 3M 5200??
    By skydog in forum General Boating Discussion
    Last Post: 04-12-2004, 09:14 PM
  5. How to get off 3M 5200??
    By skydog in forum Technical Discussion
    Last Post: 04-12-2004, 10:56 AM
