Results 1 to 13 of 13
    Nov 2013
    Eustis Florida
    Enrichener solenoid
    1992 2.5 L 175 horse. Difficult cold starting. Sometimes have to squirt fuel into carbs to start. Enrichener valve seems to only allow a tiny amount of fuel flow even when depressed manually ony one or two drops at a time come through. All hoses are patent and fuel flows freely from the carb float bowl. I recently replaced the non functioning enrichener, but even though new, it still only lets a tiny amount flow. Seems wide open when I blow through it with valve depresse.
    WTF??
    Mar 2004
    Brooklyn Park, MN
    correct gasket between the carbs and intake with the hole to let the fuel into the intake from the top of the carb?
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Jun 2009
    Bristol, Connecticut
    You replaced the enrichener so the enrichener will work but did you position it at the right height when you installed it? You dont want the fuel to have to run upwards into the enrichener...just like how the enrichener works better sometimes with the trim down
    Nov 2013
    Eustis Florida
    Yes
    Nov 2013
    Eustis Florida
    Quote Originally Posted by Aaronhl View Post
    Line from top carb float bowl to enrichener is definitely downhill.
    Sep 2017
    Ashland city tn
    Can u run motor wot for long time after it starts ?
    Houston, TX
    I have to hold my key in for a manual count of 12 seconds. Then if it doesn't start, 10 more. Then she catches.
    TX......somewhere?
    trim level or a tad negative... hold key in while crankin' tha thing till it farts, spits or tries ta start... if it doesn't start first time, raise fast idle a touch and hit start again without enrichner depressed... some will not put enough fuel in 'em with tha pre "turn over" bumps of "any length of time"..........
    Nov 2013
    Eustis Florida
    Once it starts, its fine.
    TX......somewhere?
    yeah, thats normal after initial cold start........... jus takes a lotta fuel ta start a cold one.. seems every carb merc is different with its little quirks with "cold starts".. findin' what it likes takes some playin' 'round a bit.
    Oct 2018
    New Jersey
    You may want to take the fuel hoses off and make sure they are clear and no bends in the routing. I actually increased the size of the hose to 3/16" ID from and to the enricher and 1/8" between the second and third carb. The 3/16" seems to be a good fit to the fittings. i also used a small sta-strap for added security.
  12. #12
    Jun 2009
    central minnesota
    why not supply fuel from a pressurised carb supply line?do it all the time-th
  13. #13
    Houston, TX
    On the first start of the day, I literally do a 10-12 count with key pushed in. then bump the starter. Usually takes another 8-10 count and then she fires right up.
  1. 86 175 enrichener valve location?
    By mrbrown663 in forum Technical Discussion
    Last Post: 05-27-2013, 10:34 AM
  2. Converting WH-1 carbs from flapper choke to enrichener setup
    By bigshrimpin in forum Technical Discussion
    Last Post: 11-04-2007, 10:48 AM
  3. Merc V6 enrichener valve keeps opening
    By Alan Power in forum Technical Discussion
    Last Post: 09-11-2006, 03:31 PM
  4. Merc 260 enrichener question
    By nelson edens in forum Technical Discussion
    Last Post: 08-07-2004, 10:54 PM
  5. Enrichener Valve Malfunction
    By Liqui-Fly in forum Technical Discussion
    Last Post: 07-05-2001, 08:12 AM
