Results 1 to 12 of 12
07-10-2020, 06:04 AM #1
WTB stock 150-225 2 stroke Carb Merc motor
NO LONGER LOOKING, THX
Just bought a Bass Boat again and looking to replace the current under powered Yamaha motor with a (FRESH WATER) turn key Merc 2 stroke carb motor. Carb motor preferred but open to an EFI. Looking to see what's out there......
Thanks
07-10-2020, 06:53 AM #2
I've got a 95 mag 3 150 powerhead on a 91 mid and lower $1800. Clean freshwater motor but it's in Mississippi
Cheaters never Win !!!
07-10-2020, 06:57 AM #3
FORBESAUTO liked this post
07-10-2020, 07:01 AM #4
07-10-2020, 10:50 AM #5
I've got a '85 200 carb 2.4 in real good shape...see the following thread: https://www.screamandfly.com/showthr...-oil-injection
1990 Collins Mirage - 15" 260
25 hp Merc with dry side pipe
07-10-2020, 12:10 PM #6
1:87-1. I'm working out of town till next Saturday most likely. Only pic I have on my phone. Compression was even at 125 when I got the powerhead. Six01-551-1350. Thanks Mike
07-11-2020, 04:40 AM #7
07-11-2020, 06:50 AM #8
Usually after 7pm central time we are wrapped up for the day. Working 12's to try and get done as quick as possible. Talk this evening. Thanks Mike
07-11-2020, 09:01 AM #9
tunnelmike liked this post
07-12-2020, 03:54 AM #10
07-12-2020, 06:36 AM #11
Standard size case. I'd have to check the diameter. It's not the small xr6 case.
07-12-2020, 06:42 AM #12
Need info on lifting eye for 4 stroke 150 carb motor- non Verado
By CircleHook in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 3Last Post: 03-17-2017, 04:26 PM -
122 w stock 200 carb motor
By tcrabtree in forum General Boating DiscussionReplies: 227Last Post: 08-17-2013, 10:31 AM -
Bought 1997 Merc OS Carb 225 3.0, and parts motor EFI..Can I use efi on carb engine
By Zoomba in forum Technical DiscussionReplies: 2Last Post: 02-19-2012, 08:59 AM -
2005 Mercury 200 2-Stroke (Carb.) having trouble when motor reaches certain TEMP.
By josborne8 in forum Technical DiscussionReplies: 5Last Post: 01-19-2012, 11:06 AM -
2.5 245 hp carb motor stock psi on heads
By action20 in forum Technical DiscussionReplies: 10Last Post: 04-24-2003, 08:57 PM
