Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
    Apr 2016
    delray beach florida
    Im going to have the coils checked out Monday/Tuesday, i hope it is a simple fix.
  2. #17
    Daytona Fl.
    7 Post(s)
    You can do a drop cylinder test, but even that doesn't always show up. If you know of another good running 250, swap the coils. It will take 10-15 minutes
    Boat Delivery available
    Things owned. NOTHING!!
  3. Likes suerboatsuperboat liked this post
  4. #18
    Dec 2008
    San Diego, CA
    Buy one new coil and swap it from cylinder to cylinder. It will take you less then an hour to try it at all locations.
    Cheapest and easiest solution.
  5. Likes Li'l Toy liked this post
  6. #19
    So I got up to take a leak a lil bit ago . I figgert I turn the light on so I didn't bizz all over the floor before I heard water splashing .
    Same principle applies here … hope and poke might hit it the first time , or add to the frustration level …
    500+ hours and 16 years young , ain't exactly fresh , but still my favorite piece to start with ..
    How much fuel pressure does it have ? It has a shrader valve , use a tire gauge .
    Under 40 psi and it prob needs a kit in the pulse pump .. A bad one will cause the hi-pres pump to cavitate , over 45 and the little screen under the regulator is clogged .
    Are all the plugs black as my bathroom with the lights off .. ?
    Load test the battery . ? Dead cell . ? Alternator putting out 14.5 volts @ 50 amps .?
    Is one plug black ? The rest cinnamon .. strike that .. the rest look like they are firing ?
    Before you insist it's a CDM (coil) .. test them . One black plug could be a CDM . The Motorola is a high dwell spark .. so it could even be the guy before the black plug ..
    Easy to test … Left to Right A B C D E .. >
    All three temp sensors are the same .. temp on left / ohms on right .. check at ambient temp and either heat or put an ice cube on the heads / plenum, if it moves , it's good ...
    crank trigger eye usually is either good or bad , but check it anyway .
    Make sure the TPS makes the full sweep within spec ...
    Check the MAP sensor and pull it our and shoot some brake clean in the little hole , shake it out .. maybe do it a couple times if oil is drippin out of it ..
    Old azz plug wires .. ? I buy the spiral core 8mm house brand from Jegs . they even gotz em in your boat color ... I miss my 21' Superboat ..
    FWIW .. I like NGK BR8HS plugs .. gapped to .028 - .030 Don't buy the -10 at the end .. they are gapped @ .040 / 1.0mm .. well .03937 .. way to much ..
    Dayum~id .. now I gotta go bizz again ...
    <strike></strike><strike></strike><strike></strike>
  7. Likes vnemous, noli liked this post
  8. #20
    Nov 2002
    New Jersey/ Florida
    Your hired!
    Life Begins At 100 MPH
  9. Likes vnemous liked this post
  10. #21
    Quote Originally Posted by mercace View Post
    Your hired!
    Ahh , Dad , I think I bought the book from you …
    There are 949.36 miles from Toms River to Palm City in southwest direction and 1,148 miles (1,847.53 kilometers) by car, following the I-95 S route.Toms River and Palm City are 17 hours 48 mins far apart, if you drive non-stop
    It's a little too far to drive back and fourth every day .. think you could just send me my allowance every .. err ... twice a week ... <strike></strike>
    <strike></strike>
  11. Likes vnemous liked this post
  12. #22
    Apr 2016
    Thank you for the input everyone, We figured out why she was going slow. It was a stretched throttle cable. Just replaced it now I am back in the low 70's with a full tank.
  13. Likes HydroSkreamin, WavetoWave liked this post
  14. #23
    Sep 2012
    Thanks for giving an update....That issue never crossed my mind.
  15. Likes suerboatsuperboat liked this post
  1. after market tilt slowed top speed?
    By 40mphjon in forum Technical Discussion
    Last Post: 03-26-2015, 07:00 AM
  2. Pitts 21' Superboat vs Hosers 21' Superboat
    By Dirk Pitt in forum General Boating Discussion
    Last Post: 06-12-2011, 09:19 AM
  3. Live superboat race at 1pm on superboat.com turbines and all
    By 200VEGAS in forum General Boating Discussion
    Last Post: 05-22-2011, 11:59 AM
