Results 1 to 15 of 23
    Apr 2016
    delray beach florida
    21 superboat slowed down
    So, I have a 1987 21" Superboat. It has a 12" setback and It is rigged with a 2004 mercury 250 3.0 with 520 hours. The boat used to run 72-74 mph all day at 5,200-5,400rpm. Over the past few months, It has been going slower and slower. It currently only does 63-64mph at 5,000-5,150rpm. I brought it to my mercury mechanic and he went over the entire entire top to bottom. Compression was strong, plenty of spark, and a clean fuel system. I run a trophy 26P propellor and have since i got the boat. About 100 hours ago I replaced the propellor with a brand new propellor, same one. The boat was still running 72-74mph after getting the new propellor.
    If it isn't the engine and it isn't the propellor, what could be wrong with the hull? The boat does not sit crooked/lower in the water, so I do not believe the core is wet, But I have absolutely no clue what else could be slowing me down 10mph.
    Also, Could this mean the engine is due for a rebuild? Even with solid compression numbers? I have ran the boat in between 4,000-4600RPM since I got it with 262 hours on it.
    Im sure many of you guys recognize this boat.
    Any help is appreciated, Located in South Florida
ID:	469092Click image for larger version.
Name:	7f2f18af-0e87-4406-93bf-98101f5 1.41.39 PM.jpg
    What is your WOT? Should be 5750 I believe.
    Apr 2016
    You are right, the engine can spin up to 5,750. It used to spin to 5,400, now it only spins 5,100. I have not changed anything
    Feb 2019
    Plainview, NY
    injectors are clogged probably
    Apr 2016
    Quote Originally Posted by jcoop421 View Post
    I had the injectors cleaned recently. I just had the entire engine gone over and it was nothing on the engine. Could the engine be tired? even though compression numbers are fine?
    Sep 2012
    Might be dropping a coil.
    #2 iron from the Mayo clinic, Fla. / Blue Ridge, VA.
    is that on gps ?
    most overnite successes usually take at least 10 years
    Certified turd polisher,
    Western Pennsylvania
    Shouldn't loose 10mph with only 200-300rpm decrease. Have a scanner to verify RPM with tach?
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
  9. Thanks KIRCHNER thanked for this post
  10. #9
    Apr 2016
    Quote Originally Posted by mr fun View Post
    is that on gps ?
    Yes, Garmin GPS
  11. #10
    Apr 2016
    I have a Tac and the mercury smartcraft to verify
  12. #11
    Check to see if the boat is wet
    21 Intimidator 300x Sold
    http://www.youtube.com/watch?v=KBoYUJ58sLE
    1/2 21 Skater 300x Sold
    http://www.youtube.com/watch?v=tKNFL8b6kWo
    30 Activator 850 HP Sold
    https://youtu.be/NZgOTNGKzqg
    30 Concept Twin 300Rs
  13. Likes vnemous, bayman96 liked this post
  14. #12
    Apr 2016
    Quote Originally Posted by Trimmed Out15 View Post
    That was the next thing I was going to do. I dont know what else It could be. I talked to my mechanic today and he said that everything on the engine was good. The only thing I can think of is that the core is wet.
  15. Likes powerabout liked this post
  16. #13
    Quote Originally Posted by suerboatsuperboat View Post
    Tap the bottom with the handle end of a screw driver and you will hear the difference between wet and dry
  17. Likes suerboatsuperboat liked this post
  18. #14
    Daytona Fl.
    7 Post(s)
    Probably a coil. It won't show up on a scanner. You will lose 10 mph instantly. Either that or you are eating too many donuts?
    Boat Delivery available
    Things owned. NOTHING!!
  19. #15
    Jul 2001
    NYC
    do you have to trim out more than usual to get to the current rpms? That is always the sign on my 30 that I dropped a coil , I lose 5-8 miles easily with just one coil Down - hope it’s something simple
    1982 12' Eli with 7.5 Evinrude (sold)
    1963 16' Glasspar with 40 hp Evinrude (sold)
    1969 13' Boston Whaler with 40 hp Evinrude (sold)
    1990 20' Searay with Merc i/o (sold)
    1990 22' Activator with 2.5 EFI (sold)
    1998 24' Superboat Step Hull with 300 Pro Max (sold)
    1983 21’ Shadow with 300 promax
    2003 13’ Boston Whaler with 40 hp Merc
    1976 16' Superboat with 75 Yamaha
    2010 30' Superboat Center Console with twin 300 Mercs
    One good hour on the water will make you forget 24 bad hours on land
  20. Likes suerboatsuperboat, bayman96 liked this post
  1. after market tilt slowed top speed?
    By 40mphjon in forum Technical Discussion
    Last Post: 03-26-2015, 07:00 AM
  2. Pitts 21' Superboat vs Hosers 21' Superboat
    By Dirk Pitt in forum General Boating Discussion
    Last Post: 06-12-2011, 09:19 AM
  3. Live superboat race at 1pm on superboat.com turbines and all
    By 200VEGAS in forum General Boating Discussion
    Last Post: 05-22-2011, 11:59 AM
