Results 1 to 7 of 7
Thread: mercury gearcase housing fitment
07-08-2020, 03:00 PM #1
Is this a big bearing case and will my 2.5 torque master guts go into it? 1647-9148t93
07-08-2020, 11:54 PM #2Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
ive never seen that number ???? casting numbers are what i go by, book numbers are of no use to me , it is cast into the case tail section if it does not read 1647 9147 ,1647 9147C or C1 it is not a big bearing consumer style case hipo cases not included T/Master ,CLE , Sporty
Baker343 thanked for this post
07-09-2020, 06:41 AM #3I may be slow but im ahead of you. *hit's only ankle deep but you went in head first.
07-09-2020, 07:25 AM #4
07-10-2020, 11:08 PM #5Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
or c or c1
07-11-2020, 05:57 AM #6
Just making sure thanks texas.
07-11-2020, 05:27 PM #7
The small bearing case has 2 little anodes above the cav plate bolted both sides together, the big bearing case has slots in the same area no anode, if that helps
Peter Thomas
OMC Tech: Gearcase Fitment and Swap
By Gordon02 in forum Technical DiscussionReplies: 3Last Post: 09-02-2019, 10:19 PM -
Mercury gearcase housing
By Brack in forum Lower UnitsReplies: 0Last Post: 08-25-2019, 07:11 PM -
new mercury V6 gearcase housing
By Christopher Willis in forum Lower UnitsReplies: 1Last Post: 03-23-2014, 03:52 PM
