Results 1 to 7 of 7
    Aug 2009
    mpls,mn
    mercury gearcase housing fitment
    Is this a big bearing case and will my 2.5 torque master guts go into it? 1647-9148t93
    Jul 2002
    FT WORTH, TEXAS
    ive never seen that number ???? casting numbers are what i go by, book numbers are of no use to me , it is cast into the case tail section if it does not read 1647 9147 ,1647 9147C or C1 it is not a big bearing consumer style case hipo cases not included T/Master ,CLE , Sporty
  3. Thanks Baker343 thanked for this post
    Aug 2009
    mpls,mn
    Quote Originally Posted by TEXAS20225 View Post
    That's what I thought,my tm housing cracked again now case is toast.I posted here looking for a case tm,cle etc no replys so ebay has a few but list them as 1647-9148 this is just a spare so I just need a case to put my tm guts in,so im running my sporty now.
    Aug 2009
    mpls,mn
    Quote Originally Posted by racervboat View Post
    so my tm guts will go in any 1647-9147 case?
    Jul 2002
    FT WORTH, TEXAS
    or c or c1
    Aug 2009
    mpls,mn
    Just making sure thanks texas.
    Feb 2003
    Auckland - New zealand
    The small bearing case has 2 little anodes above the cav plate bolted both sides together, the big bearing case has slots in the same area no anode, if that helps
    Peter Thomas
  1. OMC Tech: Gearcase Fitment and Swap
    By Gordon02 in forum Technical Discussion
    Last Post: 09-02-2019, 10:19 PM
  2. Mercury gearcase housing
    By Brack in forum Lower Units
    Last Post: 08-25-2019, 07:11 PM
  3. new mercury V6 gearcase housing
    By Christopher Willis in forum Lower Units
    Last Post: 03-23-2014, 03:52 PM
