Results 1 to 15 of 25
    Jun 2018
    Floating around
    15" mid V-king questions
    I have a stock fishin 98 200 efi that Im starting with. I also have a notched lower unit so does that mean I can use the 200efi clamp and trim assembly with a 15" mid? Are there any 15" mid sections that exhaust through the prop or no? Whats a dry stack all about? Im sure I will have more questions but its a start. Thanks gents
    to the top
    You cutting down the transom? Running a drop bracket?
    Jul 2012
    Lufkin, Texas
    The "saddle" on the clamp has to be shortened as well as the tiller, shift shaft, and water pipe. So, "no." The V-King was designed for a 20" V6 so you're going to need more mods than that to get it set up properly on your boat. It can be done successfully, look at Bill Foner...
    Josh Peterson
  5. Likes bayman96, tnelsmn liked this post
    Dec 2001
    Just run a 20 inch..... till 90 mph and then post....
  7. Likes LakeFever, bayman96 liked this post
    Jun 2018
    Floating around
    Thanks boys, I’m thinking the 20 will suffice for now. It ran 78 before and 90 seems far from that.
    long island
    for no reason should you have to cut or modify your transom. to cut a mid you need to start with an single ram clamp, and then have someone talented cut it or else youll break driveshafts or the mid/ clamp itself. (ronnie holzmacher, Bill foner, marty powell) are all good guys for this. If you dont wanna deal with cutting, Factory 15 is a sweet but expensive option. The boat does not need a 15, but let me tell you the handling drastically improves and if i was to ever buy another stream, it would only get a 15 inch mid.
    1978 viper - apricot 2.5 xr6 102.6mph(sold)
    1992 Stv pro comp - structurally restored, mod 200 horn motor 119 so far
    1980 21 shadow project- sold
  10. Thanks LakeFever thanked for this post
    Likes JABCO_racing liked this post
    Jun 2018
    Floating around
    Quote Originally Posted by bayman96 View Post
    Thanks for the tips.This is what I have been told by a few people and then others say its only for show hence this thread. I'm doing a new Viking build now and planning out the pieces to get there. I have time to think on this but any and all opinions are welcome
  12. Likes bayman96 liked this post
  13. #9
    Jan 2018
    Ft Myers FL
    My Vking with a factory 15" Mid. No mods to the boat just bolt on and set engine height. After a bad experience with a 15" mid that was cut I wouldn't run one again. Plenty of guys run them from one of the guys mentioned above with no problems tho.
    1983 Laser LTV
    1987 Hydrostream VKing (Sold)
    1986 Checkmate Convincor 251 OB
    Chairman of the Jackass Boating Company
  14. Likes bayman96 liked this post
  15. #10
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by JABCO_racing View Post
    Don't want to call anyone out but depending on who cut your mid that could have been the problem...
    Josh Peterson
  16. Likes bayman96 liked this post
  17. #11
    Jan 2018
    Ft Myers FL
    I agree. It wasn't any of the guys mentioned above.
    1983 Laser LTV
  18. Likes nitro_rat, bayman96 liked this post
  19. #12
    long island
    there’s a reason I didn’t mention who you and Alby had issues with hahahaha
  20. Likes nitro_rat, JABCO_racing liked this post
  21. #13
    Jul 2012
    Lufkin, Texas
    I've seen the work of two of the three good ones mentioned above and would have no issues using one of those guys! I'd steer clear of any cut bass legs for sure as they will definitely crack. Had one of those myself...
    Josh Peterson
  22. #14
    I set a 15'' on my Kings transom and I didn't think there was any way it would get water even with the sporty. Guess I was wrong. It was 2'' above the pad. Beautiful boat JABCO.....
  23. Thanks JABCO_racing thanked for this post
  24. #15
    Jan 2018
    Ft Myers FL
    That makes more sense then. Every 15" mid I've seen on a stream has had a jackplate. Bolting on the transom wouldn't let the clamp sit low enough.
    1983 Laser LTV
  1. Bozo today"I be King".." (Rather watch ol "South Park"..
    By Robby321 in forum The Scream And Fly Lounge
    Last Post: 01-21-2013, 10:02 PM
  2. BWRC '300' Enduro This Weekend! Who will be crowned "King's of the River"?
    By rossdbos in forum Upcoming Events, Races, and Gatherings
    Last Post: 10-16-2006, 06:42 PM
  3. setup for 80 v-king - 86 150 merc v6 questions
    By streaming demon in forum Props, Setup, and Rigging
    Last Post: 01-10-2005, 02:40 PM
