Results 1 to 3 of 3
07-07-2020, 04:39 PM #1New Member
- Jul 2020
- San Diego
2000 Mercury 2.5L 200 HP Outboard 20"
2000 Mercury 2.5 liter 200 hp outboard carbureted with 20” shaft. Starts right up, idles and runs under power but started making a noise 2 weeks ago. Was told it might be a broken reed or 1 cylinder. I didn’t want to bother with it as I had a newer outboard already to replace it with. Has about 300 hours and was only used in fresh water. Lower unit works great and had impeller and oil just changed. Cowling, trim and everything else in great condition. Comes with oil tank, oil lines and battery cables. It is currently off the boat and in a metal outboard crate for easy transport. I have numerous videos of it running that were taken on July 1st, right before the motor was removed from boat. I have no idea what it is worth but was told I can get up to $3,000 for it as the lower unit alone is worth over $1,000. Open to offers. It is in San Diego, CA. Call or text at 619-339-7553.
07-08-2020, 06:35 PM #25000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Can you describe the noise some more? Like at what rpms does it occur, is it constant or does it come and go, it is high pitched or low pitched, etc?
07-14-2020, 12:57 PM #3New Member
- Jul 2020
- San Diego
Sold
Glastron1987 thanked for this postGlastron1987 liked this post
2000 Johnson Outboard 250HP
By MERCSPEED in forum Outboard EnginesReplies: 1Last Post: 10-12-2016, 06:04 PM -
150 HP Johnson Outboard Yr 2000
By mragu in forum Technical DiscussionReplies: 1Last Post: 05-03-2013, 06:18 PM -
Advise on 2000 model mercury outboard
By Mallardmadness in forum General Boating DiscussionReplies: 2Last Post: 12-30-2012, 11:28 PM
