Results 1 to 6 of 6
Thread: Stupid question
    Mar 2016
    cincinnati, ohio
    Stupid question
    Ok, just replaced the Teleflex steering cable on my Sea Ray 180 Ob (I know, ain't no performance boat, slow, but it's what I got, and I love 'em). Anyway, It has a 1980 140 horse inline on it and there are two (2) mounting holes to attach the linkage to, one close to the engine and another 2+- inches further away from the engine, which one do I want to use and why??? There is only one hole closer to the engine on my 1971 115 Merc.
    Jan 2020
    Pinole, Ca
    The two holes are there to make stupid people scratch their heads and take their boat in to the shop
    1990 Collins Mirage - 15" 260
    25 hp Merc with dry side pipe
    does one hole have threads?
    Mar 2016
    cincinnati, ohio
    Both holes are the same, both threaded.
    Apr 2017
    pa
    5 Post(s)
    its probably for different length steering links, maybe dual motor setups? Use the one that lines up the best when your steering is dead center and motor is straight?
  6. Thanks 1954bmw thanked for this post
    Jan 2020
    Pinole, Ca
    Yeah, they are both the same, you can hook to either one that is easiest to get to. The inner hole will give you a tiny bit more steering but it doesn't really matter. Most boats you see have it set up in the outer hole because it is easier to get the bolt in. Also, if you ever go to a front mount hydro cylinder the bolt will probably only line up with one of the holes (unless you get different offset brackets).
  8. Thanks 1954bmw thanked for this post
    Likes rgsauger liked this post
  1. is this another stupid question
    By TEXAS20225 in forum Technical Discussion
    Last Post: 11-10-2013, 09:16 AM
  2. May be a stupid question
    By omcnut in forum General Boating Discussion
    Last Post: 06-23-2009, 07:54 PM
  3. stupid question
    By sidewinderjames in forum General Boating Discussion
    Last Post: 03-25-2007, 07:51 PM
  4. stupid question !!!
    By keypilot in forum Props, Setup, and Rigging
    Last Post: 02-28-2004, 09:47 PM
  5. Probably a stupid question
    By bullet19 in forum Technical Discussion
    Last Post: 08-19-2003, 09:04 AM
