Results 1 to 9 of 9
Thread: 2.4 vs 2.5 build
07-06-2020, 10:13 PM #1
2.4 vs 2.5 build
So I've been planning to sleeve a burned cylinder and add a new piston in my 2.4 200 carb. I just found a 93 2.5 efi that needs a piston also but everything else seems to be there. I can get it pretty cheap. Have not pulled the heads to look first hand but will. I Know my 2.4. Dont know the 2.5. Generally speaking, what do folks think of carbs vs efi? Could I sell the efi and use my 2.4 carbs and intake? WH46 carbs. Any idea what mid is worth? Trying to figure out which way to go. Thanks
07-06-2020, 11:27 PM #2
Yes, get the 2.5 and throw your 2.4 carbs on it. Either get a 2.5 carb intake or slot the middle bolts on the 2.4 intake to fit.
07-06-2020, 11:29 PM #35000 RPM
- Mar 2015
- DFW
- 665
- 16
- 42
- 366
- 232
EFI in my experience is more reliable and efficient. However, EFI also usually means more expensive when something needs to be worked on too.
07-07-2020, 05:35 AM #4
If u do decide 2.5. You will want all new pistons , cause no telling the hrs or how many times it got little warm etc , 2.5 little cheaper on machine work also
Noah Burns liked this post
07-07-2020, 07:08 AM #5
07-07-2020, 07:08 AM #6
Is that fuel injection worth anything if I yank it and put my carbs on?
Clean motor. Still got the oil injection tank on it. Sounds like an injector screwed up and burned the piston.1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
07-07-2020, 08:13 AM #7
rgsauger thanked for this post
07-07-2020, 11:05 AM #8
Thanks Bullet123. I'll find out the details. I think I'll probably stay with the carbs if I go the 2.5 route - call me old school.
07-07-2020, 12:39 PM #9
We NEED to build one of these!
By Scream And Fly in forum The Scream And Fly LoungeReplies: 9Last Post: 04-21-2019, 08:48 PM -
Best workstand to build powerheads? Build? Buy?
By Zoomba in forum Technical DiscussionReplies: 6Last Post: 03-10-2014, 07:45 PM -
Build better and Safer Build Union
By SnakeBit in forum The Scream And Fly LoungeReplies: 38Last Post: 09-06-2008, 05:00 PM -
2.4 build
By CREWSMARINE05 in forum Technical DiscussionReplies: 6Last Post: 03-15-2007, 07:10 PM
