Results 1 to 4 of 4
    Long Island N.Y.
    CLEs with Bob's cones or Tie Bar Issue, which?
    Guys/Gals
    First time out this season on my 21 twin cat and I noticed I lost some speed on top end (6 mph) from last season. The only things changed over the winter was I had Bob' cones with low water pickups installed on my pair of CLEs, and I also had the tie bar shortened by 7/16, so I now only have 1/8" toe-in (heard that worked well on these boats). Motors are still 7600 rpms, same as last year
    Your thoughts what it could be?
    Thanks
    Frank
    Aug 2006
    GA
    Try a tie bar the length b4 it was shorten ..
  3. Likes rgsauger liked this post
    Mar 2015
    DFW
    Just curious, why did you add the cone to an already coned lower? I know it is something that is done pretty often, just curious why you did it in particular.
    Long Island N.Y.
    Heard that the Bob’s run faster than stock CLE
  1. Parting out 1993 2.5 245 and late 80s Bridgeport both fresh water. 2 CLEs
    By at100plus in forum Misc. Parts and Accessories
    Last Post: 07-23-2017, 08:18 AM
  2. Mercury Tech: Dual temp gauges issue OR engine Issue
    By dompie99 in forum Technical Discussion
    Last Post: 05-24-2016, 09:37 AM
  3. 250xs top cowl melting common issue or is there an internal issue I should look for
    By 150aintenuff in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 08-30-2015, 05:14 PM
  4. Nose coned CLEs?
    By Techno in forum General Boating Discussion
    Last Post: 07-06-2007, 07:05 PM
