Results 1 to 4 of 4
07-06-2020, 06:41 PM #1
CLEs with Bob's cones or Tie Bar Issue, which?
Guys/Gals
First time out this season on my 21 twin cat and I noticed I lost some speed on top end (6 mph) from last season. The only things changed over the winter was I had Bob' cones with low water pickups installed on my pair of CLEs, and I also had the tie bar shortened by 7/16, so I now only have 1/8" toe-in (heard that worked well on these boats). Motors are still 7600 rpms, same as last year
Your thoughts what it could be?
Thanks
Frank
07-06-2020, 08:23 PM #25000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
Try a tie bar the length b4 it was shorten ..
rgsauger liked this post
07-06-2020, 11:26 PM #35000 RPM
- Mar 2015
- DFW
- 665
- 16
- 42
- 366
- 232
Just curious, why did you add the cone to an already coned lower? I know it is something that is done pretty often, just curious why you did it in particular.
07-07-2020, 05:52 AM #4
Heard that the Bob’s run faster than stock CLE
Parting out 1993 2.5 245 and late 80s Bridgeport both fresh water. 2 CLEs
By at100plus in forum Misc. Parts and AccessoriesReplies: 16Last Post: 07-23-2017, 08:18 AM -
Mercury Tech: Dual temp gauges issue OR engine Issue
By dompie99 in forum Technical DiscussionReplies: 4Last Post: 05-24-2016, 09:37 AM -
250xs top cowl melting common issue or is there an internal issue I should look for
By 150aintenuff in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 0Last Post: 08-30-2015, 05:14 PM -
Nose coned CLEs?
By Techno in forum General Boating DiscussionReplies: 1Last Post: 07-06-2007, 07:05 PM
