Results 1 to 13 of 13
    Jan 2006
    1998 pro max - issues
    1998 300 pro max.
    Motor has run fine all year. Idled out from launch for about 10 mins. Get on plane and within about 1/4 mile the motor just shut off like someone turned the key off. I have checked all connections and can't find anything loose. Have power from key ignition to the motor. Starter will engage but will not turn the fly wheel. I cannot turn the fly wheel by hand or with a socket wrench. Pretty sure I am guessing this is not good....but thought I would see if there are any suggestions anyone has before I dig any further into this.
    Thanks
    Pull out all 6 spark plugs. Remove the flywheel cover. Try turning again. Post results
  3. Likes TEXAS20225 liked this post
    Next. Drop the lower and and see if the flywheel spins. Mite have locked up the LU gears.
  5. Thanks ssv1761982 thanked for this post
    Likes TEXAS20225, ssv1761982 liked this post
    Sep 2017
    Ashland city tn
    I agree both good advice , u should had heard sumthin if it motor , lots time its lower unit, I'd pull it off 1st
    Western Pennsylvania
    When U pull the plugs see what they look like. Post photo of them all.
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
    Jan 2006
    I did pull all 6 plugs when returned and flywheel still did not spin. All plugs had perfect coloring as they should.
    I will drop the lower and see what happens from there. I'll be back with results once I get it dropped.
    Thanks again for all suggestions.
  9. Thanks Euroski thanked for this post
    Apr 2017
    pa
    5 Post(s)
    hopefully its a locked lower. fingers crossed
    Jan 2006
    Thank you all for the help. Pulled the lower last night and it is indeed locked up.
  12. Likes TNRoostertail, sonicss33 liked this post
  13. #9
    Sep 2017
    Ashland city tn
    U can start ur motor for a sec without lower unit and make sure it's all good also
    Quote Originally Posted by Blown Up View Post
    Lower unit locked? Or powerhead locked?
    Jan 2006
    Lower unit is locked up. Good thing is I had them rebuilt less than a year ago, so everything is still under warranty. I know it is not good, but I am actually glad to have it be the lower unit and not the powerhead.
  16. #12
    Jan 2006
    Always nice to have 2 motors to make it back in as well.
  17. Likes rgsauger liked this post
  18. #13
    Sep 2017
    Knoxville, TN
    I was also leaning to the side of the lower locking up. I have never seen a Promax go down quietly lol.
    Respect no wake zones!!! Evinrude guys need a place to race too.
  1. power issues with 1998 Johnson Ocean Runner
    By barclayrl in forum Technical Discussion
    Last Post: 06-21-2015, 07:56 PM
  2. 1998 Johnson Ocean Pro 225 any issues?
    By at100plus in forum General Boating Discussion
    Last Post: 08-28-2013, 08:16 PM
  3. Replies: 7
    Last Post: 09-13-2003, 06:56 PM
  4. 1998 Hydrostream Valero YT, 1998 Pro Max 225
    By at100plus in forum Props, Setup, and Rigging
    Last Post: 04-22-2001, 09:29 PM
