Results 1 to 15 of 20
Thread: Engine height Merc 450R
07-05-2020, 09:49 AM #15000 RPM
- Norway
- 935
- 61
- 13
- 354
- 182
Hi!
If I am correct owners of the new V8 4,6 litre 450R have experienced water pressure issues with their new engines. The new 450R loose water pressure earlier than 400R. I know that Nor-Tech have seen water pressure issues, and for that reason the speed potential of the new 450R suffer. One way is to add a transom water pickup, but for my part I would like to avoid that.
The 450R is a very expensive engine and it would be a mood killer to discover that extra speed is limited due to engine height....
I run my 400R propshaft 2 inches above the bottom. Top speed is 89-90 mph with a Max5 spinning at 7,060 rpms.
Thanks !
Cheeers, Toffen
07-05-2020, 10:11 AM #2
Would more off-set help?
Got any pictures ?We have invented the world; WE see
07-05-2020, 10:19 AM #35000 RPM
- Norway
- 935
- 61
- 13
- 354
- 182
Hi!
I have not yet ordered a 450R, but are a little alert about the water pressure issues if running high (which is essencial to get speed out of the huge lower unit). I have mounted my 400R on a stainless marine jackplate with 5 inches setback and added a noth to my transpom of about 5 inches.
Cheeers, Toffen
07-05-2020, 10:29 AM #4The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
...same old rule applies. mount it as high as it will go and still have good water pressure(and nowadays, so that no alarms are set off). make up for any slippage you might have after that, with the correct prop with the appropriate number of blades to get the job done.
07-05-2020, 10:43 AM #55000 RPM
- Norway
- 935
- 61
- 13
- 354
- 182
Hi,
In theory The lower unit of the 400R is the same of 450R. If the 450R is more sensitive to running high than the 400R, you loose speed. I use a Max5 prop now on my boat. Possibly a CNC 5 blade cleaver will offset for the lower engine height with lower slip percentage. However, my boat needs bowlift ... and a CNC cleaver will hold the bow less ..
Cheeers, Toffen
07-05-2020, 10:57 AM #6
Yeah cleaver's don't have bow lift so add more set back then you get to raise the motor more.win/win.
What about weight difference between them, looks like the 450 is a extra 100 lb.that will change the teeter-totter.
Excuse me balance point.Last edited by CUDA; 07-05-2020 at 11:53 AM.
07-05-2020, 11:54 AM #76000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
I think the 400r and 450 are very similar weights.
it is baffling though that the 300r, 400r, and 450r seem to require different heights while the housings are supposedly identical.
07-05-2020, 12:05 PM #8
May as well go all the way...
Looks like 100lbs vs
https://portaproducts.com/porta-brac...series/#photosWe have invented the world; WE see
07-05-2020, 01:06 PM #9The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
...yes, the porta is the universal antidote...
07-05-2020, 01:56 PM #105000 RPM
- Norway
- 935
- 61
- 13
- 354
- 182
07-06-2020, 07:45 AM #11
400 is inline 6- 450 is V8 water capacity would probably be more on V 8 block so they may need a little more flow
400- 668lbs 450-689lbsLast edited by perfmarine1; 07-06-2020 at 07:51 AM.
07-06-2020, 07:55 AM #12Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Another possibility is that the different blocks of the inline 6 and V8 restrict the flow differently making for the same amount of water to have different psi. One may need more volume while the other needs pressure.
Toffen thanked for this post
07-06-2020, 08:10 AM #13The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
07-06-2020, 09:42 AM #14
Dave Z and I setup his Doug Wright with 300R's and we found the sweet spot to be 2.25" above the bottom. Any higher and the engine went into limp mode for overheat.
08-13-2020, 09:00 AM #15
Limp no more. Reggie mentored me on getting water to the 400R's. We opened and profiled the water intake to the Sportmaster gear case.
Problem now is the next boat gets twin 450's with HD gear cases and I have been told water pressure is a big issue.
JPEROG thanked for this postJPEROG, stoker2001 liked this post
Merc 450R
By Toffen in forum General Boating DiscussionReplies: 4Last Post: 05-22-2019, 06:29 PM -
need help setting my engine height and jack plate height
By johnsongt175 in forum Props, Setup, and RiggingReplies: 2Last Post: 05-27-2014, 07:21 AM -
F2 Leecraft Engine set-up ( engine height )
By MirageBoy69 in forum Props, Setup, and RiggingReplies: 8Last Post: 10-30-2011, 07:47 PM -
HOW to - jack plate height/engine height
By Techno in forum Technical DiscussionReplies: 4Last Post: 08-21-2007, 12:49 PM -
Engine Height
By Coupe9050lx in forum Technical DiscussionReplies: 0Last Post: 03-05-2007, 06:35 PM
