Results 1 to 15 of 20
    Norway
    Engine height Merc 450R
    Hi!
    If I am correct owners of the new V8 4,6 litre 450R have experienced water pressure issues with their new engines. The new 450R loose water pressure earlier than 400R. I know that Nor-Tech have seen water pressure issues, and for that reason the speed potential of the new 450R suffer. One way is to add a transom water pickup, but for my part I would like to avoid that.
    The 450R is a very expensive engine and it would be a mood killer to discover that extra speed is limited due to engine height....
    I run my 400R propshaft 2 inches above the bottom. Top speed is 89-90 mph with a Max5 spinning at 7,060 rpms.
    Thanks !
    Cheeers, Toffen
    PARADISE /Naples
    Would more off-set help?
    Got any pictures ?
    Norway
    Hi!
    I have not yet ordered a 450R, but are a little alert about the water pressure issues if running high (which is essencial to get speed out of the huge lower unit). I have mounted my 400R on a stainless marine jackplate with 5 inches setback and added a noth to my transpom of about 5 inches.
    Cheeers, Toffen
    ...same old rule applies. mount it as high as it will go and still have good water pressure(and nowadays, so that no alarms are set off). make up for any slippage you might have after that, with the correct prop with the appropriate number of blades to get the job done.
  5. Likes Star1, KIRCHNER, JPEROG liked this post
    Norway
    Hi,
    In theory The lower unit of the 400R is the same of 450R. If the 450R is more sensitive to running high than the 400R, you loose speed. I use a Max5 prop now on my boat. Possibly a CNC 5 blade cleaver will offset for the lower engine height with lower slip percentage. However, my boat needs bowlift ... and a CNC cleaver will hold the bow less ..
    Cheeers, Toffen
    PARADISE /Naples
    Yeah cleaver's don't have bow lift so add more set back then you get to raise the motor more.win/win.
    What about weight difference between them, looks like the 450 is a extra 100 lb.that will change the teeter-totter.
    Excuse me balance point.
    Oct 2009
    Gonzales, La
    I think the 400r and 450 are very similar weights.
    it is baffling though that the 300r, 400r, and 450r seem to require different heights while the housings are supposedly identical.
  9. #8
    PARADISE /Naples
    May as well go all the way...
    Looks like 100lbs vs
    https://portaproducts.com/porta-brac...series/#photos
  10. #9
    ...yes, the porta is the universal antidote...
  11. #10
    Norway
    Quote Originally Posted by engineermike View Post
    Hi,
    Yes, thats strange. I will ask Wildman about his experience with 300R, 400R and 450R on his boats. It seems to that 450R loose waterpressure when higher than 1-1,5 inch above the bottom, and its a 1-3 mph on the last inch.
    Cheeers, Toffen
  12. #11
    Oct 2010
    Harrisburg,Pa
    400 is inline 6- 450 is V8 water capacity would probably be more on V 8 block so they may need a little more flow
    400- 668lbs 450-689lbs
  13. Thanks Toffen thanked for this post
    Likes Star1 liked this post
  14. #12
    May 2001
    Hickory NC
    Another possibility is that the different blocks of the inline 6 and V8 restrict the flow differently making for the same amount of water to have different psi. One may need more volume while the other needs pressure.
  15. Thanks Toffen thanked for this post
  16. #13
    ...or...maybe...crabbing comes into account...a lot of variables on the install/hull, etc...just guessing...
  17. #14
    Illinois
    Dave Z and I setup his Doug Wright with 300R's and we found the sweet spot to be 2.25" above the bottom. Any higher and the engine went into limp mode for overheat.
  18. Thanks Toffen thanked for this post
  19. #15
    Washington N.C.
    Limp no more. Reggie mentored me on getting water to the 400R's. We opened and profiled the water intake to the Sportmaster gear case.
    Problem now is the next boat gets twin 450's with HD gear cases and I have been told water pressure is a big issue.
    Attached Thumbnails Attached Thumbnails 29ni2cn.jpg   2uojmlk.jpg   img_0365_2__a020806b3cc89550a28795453678f6fa22a058f9.jpeg   quad_2_33db16bf482b8f1510ff9ec81ed56c7cbc8ab0cd.jpg
  20. Thanks JPEROG thanked for this post
    Likes JPEROG, stoker2001 liked this post
  1. Merc 450R
    By Toffen in forum General Boating Discussion
    Last Post: 05-22-2019, 06:29 PM
  2. need help setting my engine height and jack plate height
    By johnsongt175 in forum Props, Setup, and Rigging
    Last Post: 05-27-2014, 07:21 AM
  3. F2 Leecraft Engine set-up ( engine height )
    By MirageBoy69 in forum Props, Setup, and Rigging
    Last Post: 10-30-2011, 07:47 PM
  4. HOW to - jack plate height/engine height
    By Techno in forum Technical Discussion
    Last Post: 08-21-2007, 12:49 PM
  5. Engine Height
    By Coupe9050lx in forum Technical Discussion
    Last Post: 03-05-2007, 06:35 PM
