Results 1 to 15 of 17
    Jun 2020
    Mercury 250 EFI Offshore
    I recently picked up a 30" shaft Mercury 250 EFI Offshore. It has good compression, and the oil injector is disconnected (will be premixing), but I wanted some thoughts on what all I should check and replace on the motor.
    First off I'm thinking of replacing the reed valves. Any thoughts, and are there superior aftermarket reed valves that will fit this engine?
    Also I've read the ignition coils can go bad. Even if they do, this won't damage the motor, right?
    Any recommendations on the injectors?
    Also, I've read there's a difference between these EFI motors and some of the newer ones (maybe 2003 and later?). What are the differences, and how will this change how I maintain the motor?
    Thanks in advance!
    Jun 2020
    Anyone?
    Houston, TX
    Contact Chris Carson marine for a good set of reeds.
    If you drop a coil, you drop a cylinder for power but not the end of the world. They don't fail that often.
    You gotta get your injectors cleaned!!! There are numerous sponsors on here. If an injector goes lean, you melt that piston. Baaaaaad chit!
    Oct 2018
    New Jersey
    It would be a god idea to go over the fuel system from start to finish. Replace, clean or rebuild those components. Have the fuel lines been replaced especially if running ethanol blends? New water pump and poppit valve are inexpensive and worth replacing as well.
    If its a two computer motor try to find a 300pm ignition computer, that will wake it up and give you some more rpms
    Nov 2019
    Canada
    Send your injectors on down!
    www.InjectorService.com
    Call/Text - 204-326-0390
    Quote Originally Posted by InjectorService View Post
    You would be up
  8. Likes InjectorService liked this post
  9. #8
    Nov 2019
    Canada
    You would be up
    I'm sorry, I didn't realize you guys did injectors as well. Not trying to swipe business from you guys.
    Rdoaner - send em out to Fullers! Great guys to deal with!
  10. #9
    No I meant you said send them down, hes in Florida so he has to send them up to get to you
  11. #10
    Nov 2019
    Canada
    Ah I see. Man its one of those Wednesdays that feels like a Monday. Must be 5 o'clock somewhere!
  12. #11
    Ohhh ghee golly ..
    Now I'm so corn~fruzed about below the 30th and above the 45th parallels ..
    Does the E~crator to the N. pole have anything to do wiff it .. ehh ???
    All kidding aside … both shops are great people to deal with ….
  13. Likes vnemous liked this post
  14. #12
    Chaz I splaine it to you some day.
  15. #13
    Went over your head which is tough since you're so far UP there Have a good day
  16. #14
    Jun 2020
    Wow this thread really took off! PM sent to Injector Service
  17. #15
    Yes we service all injectors except FICHT. Usual Monday customer drops off and says clean and flow them all and supply calibration specs for each one. Customer gets what they want.
  1. Trade Mercury 20" offshore mid for mariner 20" offshore mid
    By ASPB in forum Misc. Parts and Accessories
    Last Post: 03-03-2017, 03:50 PM
  2. American Offshore 2600 NXS twin Mercury Offshore 280's
    By Balaco01 in forum Hulls larger than 20'
    Last Post: 03-01-2015, 01:05 PM
