Results 1 to 3 of 3
Thread: Johnson Venom 200 j200stledm
07-02-2020, 11:22 AM #1New Member
- Jun 2020
- Loudonville, Ohio
I am having problems with a carb overflowing after a rebuild. I rebuilt all six carbs and now the top left, facing the carbs, is leaking from the brass overflow. I have reset the float and change needle and seat. I even went back to an old needle since I found this problem.
I have ordered a new float bowl but I am not sure that is going to fix my problem. Have I missed anything during the rebuild? The float is set ever so slightly above level and is seated properly. I pulled the bowl off and held it upside down and tried to blow into the fuel port and it was seated and then turned it over and it was open.
Can you tighten the carb to much and distort the bowl?
Once the engine is running, fuel will flow out of the overflow constantly.
Thanks in advance
07-03-2020, 11:44 AM #25000 RPM
- Aug 2010
- Arlington, VA
- 177
- 43
- 45
- 14
Hi JoJo.
Welcome to Scream N Fly.
You posted this question in the buy-and-sell section.
You'll do much better if you post it in the right part of the forum.
07-04-2020, 02:29 PM #3
Lower the float , if u think it's to spec , just lower little more see if dont stop
OMC Tech: Johnson Venom 200
By eliminator-liberty in forum Technical DiscussionReplies: 0Last Post: 02-10-2014, 05:00 PM -
OMC Tech: 96 Johnson Venom 200 hp
By khamrick55 in forum Technical DiscussionReplies: 1Last Post: 05-13-2011, 04:32 AM -
200 hp Johnson venom
By khamrick in forum Technical DiscussionReplies: 13Last Post: 04-30-2010, 07:37 AM -
Johnson 225 Venom
By Action Frank in forum General Boating DiscussionReplies: 2Last Post: 02-08-2006, 06:08 PM -
200 Johnson Venom
By iammarcuse in forum Technical DiscussionReplies: 1Last Post: 03-05-2005, 01:59 PM
