Results 1 to 3 of 3
    Jun 2020
    Parker Dam
    1997 Mariner 225 EFI Super Magnum info
    Just purchased sitting on a 18' Mirage. OG503168 serial. Is this a 3.0 or 2.5L? There are 3 quick beeps when key turned (is this normal)? WOT RPM range? Not one to haul the mail all day, more of just a cruiser. Premix anyway to be safe and bypass oil pump? Thanks!
    Aug 2015
    Southeast
    I used to have one. 2.5 liter. Yes, better off to ditch the oil injection and premix. Think the redline is 6700 but someone else will chime in to verify. It may say so on the computer box on motor. recall one beep but again someone will comment. I had my box reprogrammed to raise the redline into the 7's but rarely ran it up there. It's the Mariner equivalent of a Merc 225 promax.
    STV ProComp w/ 225 Promax
    STV Procomp with 280
    25 Liberator "The Battleship"
    Blazer 650 Pro Tour
  3. Likes tux974, BajaT liked this post
    If you get the 3 beeps key on that's normal for stock system with oil injection and warning module. Many how to threads on here about oil injection delete, after delete will no longer have beep with key on. The STBD head temp sensor will be wired directly to harness and only beep if overheated.
  5. Likes BajaT liked this post
  1. 1997 Mariner 150 Super-Magnum
    By boat2fast in forum Outboard Engines
    Last Post: 05-29-2020, 09:25 PM
  2. 1997 Mariner Super Magnum
    By Greg G in forum Ebay Listings and Other Internet Listings
    Last Post: 06-24-2019, 07:36 AM
  3. Mariner pro max super magnum 225 efi a 2.5 or 3.0?
    By bnjackson5 in forum Racer's Hangout
    Last Post: 08-13-2008, 08:00 PM
  4. 1997 mariner super magnum Questions
    By xcr800 in forum Technical Discussion
    Last Post: 11-01-2007, 12:42 PM
