Results 1 to 10 of 10
06-28-2020, 01:32 PM #1
Promax 225 Poper Valve & Thermostat Question
Hi Merc Tech‘s,
I have twin 225 Promax on my Tunel and my mechanic recommended to replace with new thermostat w/seal, and poper valve System wich I find smart to do since Powerheads are new to me but used.
He mentioned that he has done in some racing preps a popper restrictor and deleted the thermostat and forget of any of them failing.
Would you do this mod. or stay with the systems as designed by Mercury?? I had in mind to stay stock.
Regards,
RaulLast edited by rarias; 06-28-2020 at 01:35 PM.
06-28-2020, 02:49 PM #2
Well kinda depends on use of motors. But for normal use. stats and poppet , as long it's still on the 2 piece adapter plates
06-28-2020, 03:58 PM #3
Pleasure and maybe 2 races a year.
regards,
06-29-2020, 04:06 AM #4Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
No need to change. Stay stock.
rarias liked this post
06-29-2020, 05:09 AM #5
Stats, popet kit, and pulse pump rebuild would be my suggestion especially in salt if you are running a 2pc plate (stock cooling setup).
If you are running a 1pc adapter plate then you can run restrictors in place of stats but that should have been done already.
If you are not sure what you have post a picture of the back of the engine up close without cowling to best help you.
TEXAS20225, rarias liked this post
06-29-2020, 07:16 AM #6
looks like 2 piece maybe???
TEXAS20225 liked this post
06-29-2020, 11:35 PM #7
06-29-2020, 11:36 PM #8
Appreciate your recommendations. Hope this picture helps.
06-30-2020, 05:13 AM #9
Looks like you have a popet dump hose going to the top of the block so that tells me you have stock cooling with stock 2pc setup.
I suggest to leave it alone. Replace stats (143*) every year, at minimum check/clean popet but best to replace with complete kit especially in salt water.
If you do not know engine history or when last properly serviced rebuild pulse pump and clean VST. Having injectors serviced is also a very good idea but that will take a bit of work.....MPO.
tlwjkw, Dave Strong liked this post
06-30-2020, 09:33 PM #10
mercury xr6 poppet valve and thermostat replace?
By dblount in forum Technical DiscussionReplies: 2Last Post: 01-05-2017, 08:38 AM -
Mercury Mark 20H Poper
By Ray Long in forum Outboard EnginesReplies: 0Last Post: 11-27-2016, 05:56 PM -
OMC Tech: Thermostat bypass valve grommet question on V6 Crossflow
By Steve2ManyBoats in forum Technical DiscussionReplies: 2Last Post: 10-18-2010, 06:36 AM -
1988 80 hp mercury thermostat and poppit valve replacement
By 370VRanger in forum Technical DiscussionReplies: 0Last Post: 07-30-2008, 02:33 PM -
300 promax thermostat or no thermostat
By SPECTRE racing in forum Technical DiscussionReplies: 5Last Post: 12-15-2005, 11:46 PM
