Results 1 to 10 of 10
    Sep 2006
    Miami, Fl.
    Promax 225 Poper Valve & Thermostat Question
    Hi Merc Tech‘s,
    I have twin 225 Promax on my Tunel and my mechanic recommended to replace with new thermostat w/seal, and poper valve System wich I find smart to do since Powerheads are new to me but used.
    He mentioned that he has done in some racing preps a popper restrictor and deleted the thermostat and forget of any of them failing.
    Would you do this mod. or stay with the systems as designed by Mercury?? I had in mind to stay stock.
    Regards,
    Raul
    Attached Thumbnails Attached Thumbnails 3588A083-DEEB-4345-8190-B0F7C235E4C5.jpg   60ECD96F-E9DA-4AC0-8018-DB4E4155ED1D.jpg
    Sep 2017
    Ashland city tn
    Well kinda depends on use of motors. But for normal use. stats and poppet , as long it's still on the 2 piece adapter plates
    Sep 2006
    Miami, Fl.
    Pleasure and maybe 2 races a year.
    regards,
    Jul 2004
    Connecticut
    No need to change. Stay stock.
  5. Likes rarias liked this post
    Stats, popet kit, and pulse pump rebuild would be my suggestion especially in salt if you are running a 2pc plate (stock cooling setup).
    If you are running a 1pc adapter plate then you can run restrictors in place of stats but that should have been done already.
    If you are not sure what you have post a picture of the back of the engine up close without cowling to best help you.
  7. Likes TEXAS20225, rarias liked this post
    TX......somewhere?
    looks like 2 piece maybe???
  9. Likes TEXAS20225 liked this post
    Sep 2006
    Miami, Fl.
    is Click image for larger version.
    Sep 2006
    Miami, Fl.
    Appreciate your recommendations. Hope this picture helps.
    Looks like you have a popet dump hose going to the top of the block so that tells me you have stock cooling with stock 2pc setup.
    I suggest to leave it alone. Replace stats (143*) every year, at minimum check/clean popet but best to replace with complete kit especially in salt water.
    If you do not know engine history or when last properly serviced rebuild pulse pump and clean VST. Having injectors serviced is also a very good idea but that will take a bit of work.....MPO.
  13. Likes tlwjkw, Dave Strong liked this post
    Sep 2006
    Miami, Fl.
    Hi Tux974,
    stayed all original and installed new popet kit and thermostat 143 with seal as recommended. There is a water tube that conectes to a plastic T divider and goes to the upper plate where the bushings are. What is the reason of this water??? (See pics)
  1. mercury xr6 poppet valve and thermostat replace?
    By dblount in forum Technical Discussion
    Last Post: 01-05-2017, 08:38 AM
  2. Mercury Mark 20H Poper
    By Ray Long in forum Outboard Engines
    Last Post: 11-27-2016, 05:56 PM
  3. OMC Tech: Thermostat bypass valve grommet question on V6 Crossflow
    By Steve2ManyBoats in forum Technical Discussion
    Last Post: 10-18-2010, 06:36 AM
  4. 1988 80 hp mercury thermostat and poppit valve replacement
    By 370VRanger in forum Technical Discussion
    Last Post: 07-30-2008, 02:33 PM
  5. 300 promax thermostat or no thermostat
    By SPECTRE racing in forum Technical Discussion
    Last Post: 12-15-2005, 11:46 PM
