Results 1 to 13 of 13
Thread: 225 Promax offshore trim issue
06-28-2020, 11:15 AM #1Member
- Feb 2019
- Midwest
- 82
I have a 225 promax with an offshore mid. It's a mercury racing pump. Serial number is 004512.
I've been having a slow trim issue but it only struggles going up when past the half way point.
I'll give you a scenario. Let's say the engine is trimmed all the way down. I'll start trimming up and it works fine. Then once it gets a little above halfway, it slows down. Then it struggles so bad that it won't even trim anymore. The trim motor will be running and the engine will barely be going up. It get's going so slow that it looks like it's hardly moving.
I think it's either the motor is bad or it needs primed.
I just replaced the reservoir cap because it was cracked. Also, it used to screech/ squeak when I would let off the trim. I assumed it did that since it sat in storage for a while. After I used it more, it quit squeaking.
06-28-2020, 11:18 AM #2Member
- Feb 2019
- Midwest
- 82
06-30-2020, 07:41 PM #35000 RPM
- Sep 2014
- Iowa
- 280
- 16
- 44
- 89
Does the pump sound like it is slowing down/changing pitch when the trim slows down? Any "bubbly" noise? The pump could be cavitating. I suppose you also could have a bent trim cylinder and the pump is hitting the relief pressure and bypassing the cylinder.
To address your one point, these pumps are self priming since they are a gear pump with a reservoir where the air pockets can return back to tank. Typically this is done just by trimming from full down to full up and back several times.
06-30-2020, 07:56 PM #46000 RPM
- Nov 2006
- 1,491
- 13
- 129
- 70
- 626
- 35 Post(s)
Trim Pump Struggles
Could be debris or sludge in the lines? Try changing out the trim oil. Make sure the cap has a tiny vent hole in it. If it doesn't vent you'll get an airlock stall. When racing, I never bothered to use SAE 20W and used hydraulic jack oil instead (purpose blend for jacks, hydraulic rams, tractors, etc). Sounds to me like the pump is starved for an oil supply?
06-30-2020, 08:54 PM #5Member
- Feb 2019
- Midwest
- 82
06-30-2020, 08:55 PM #6Member
- Feb 2019
- Midwest
- 82
07-01-2020, 01:53 AM #76000 RPM
- Nov 2006
- 1,491
- 13
- 129
- 70
- 626
- 35 Post(s)
Trim Reservoir
Per your photo, you can see the fluid level in the reservoir. When you trim in, fluid is pumped back IN to the tank. When you trim OUT the fluid level should drop. Try running the trim without the cap on. If the level doesn't drop at some point trimming out then the valve body should be disassembled, cleaned and inspected. It could be be debris fouling up a spring loaded ball valve seat. I'm betting you have a misrun cap with no venting.
07-01-2020, 04:15 PM #8Member
- Feb 2019
- Midwest
- 82
07-01-2020, 05:13 PM #96000 RPM
- Nov 2006
- 1,491
- 13
- 129
- 70
- 626
- 35 Post(s)
07-01-2020, 06:00 PM #10The Historic Photo Master
- Jan 2004
- Florida
- 37,827
- 64
- 1667
- 337
- 19201
- 3 Post(s)
07-01-2020, 07:43 PM #11Member
- Feb 2019
- Midwest
- 82
07-01-2020, 09:39 PM #126000 RPM
- Nov 2006
- 1,491
- 13
- 129
- 70
- 626
- 35 Post(s)
07-06-2020, 08:46 AM #13Member
- Feb 2019
- Midwest
- 82
Mercury Tech: 225 ProMax issue
By sv10001975 in forum Technical DiscussionReplies: 9Last Post: 05-18-2019, 07:46 PM -
Merc Promax 3.0L Offshore Mid + Trim Pump - Freshwater
By Speeddemon129 in forum Misc. Parts and AccessoriesReplies: 9Last Post: 09-19-2018, 01:10 PM -
300 promax/x mid offshore complete with trim pump
By 87EluderBP in forum Misc. Parts and AccessoriesReplies: 1Last Post: 03-11-2018, 05:54 PM -
electrical trim gauge 300 promax w/offshore bracket
By demag67 in forum Technical DiscussionReplies: 4Last Post: 05-06-2014, 04:24 AM -
2.4 BP Offshore EFI lower unit issue
By stokernick in forum Technical DiscussionReplies: 6Last Post: 06-25-2006, 10:18 PM
