Results 1 to 2 of 2
    Promax vst drlete
    My 1995 promax still has the stock Vst and blazer front. I want to convert it to the 260 style fuel setup.
    My vst has the older style system where the high pressure pump is external of the tank. It is a Bosch. Can I still use this pump to put inside the boat? Also my 39# reg uses a O ring to seal against the Vst so I will be needing to tap threads into the return side of it for a barb fitting to return back to the fuel cell in the boat.
    Attached Thumbnails Attached Thumbnails 15932987262232318785160698121076.jpg   20200627_174152.jpg   20200627_174200.jpg   20200627_174223.jpg   20200627_174906.jpg
    Thebes, Il.
    Very good question-I have same setup and 2 of those Bosch pumps. 1 new in box and one with 11 hrs that was put on when Jay built my motor 3 yrs ago. I have one of the regulators already drilled -tapped and barbed. Just wanted to get motor broke in good and be sure no issues anywhere so if I changed to a Prostock setup i could be confident motor fuel and electric where good before I did it. Right now I have a jegs low pressure pump suppling VST in place of the pulse pump at Jay's recommendation for my build, he tapped pulse pump hole and it is plugged. In my mind the Bosch pumps we have should be good since they were what was factory anyway. Just mount low by tank and filter before etc like alot do in that setup- Diamond had a great plumbing setup that most follow with great success. Let me know if you do it and post up or pm pictures. I'll do same if I beat you to it. I don't get to water much, hence a 3 year old build and only 11 hrs. Go to Kinkaid Lake in Il below Chester. 50 MPH limit so not alot of running do to limit and congestion. I'm going in am early before the holiday boaters get out. Where you boat over there, good hotboat crowd? be safe abd good luck.
    Current-
    '89 Allison XB2002 Comp/Pro Center Steer Maroon on Sandstone
    '98 ProMax 225 JSRE
    20" Mid- Jaco's Ally worked SportMaster 1.87 gears
    Past-
    '96 Allison XB2003 PST White w/ Red Tips accent Stripe
    '89 GT175 w/Bob's Bigfoot LWP
    '97 Cobia 22BR 5.7 MercCrusier/ Bravo
    '85 STV Sprint --2.5 Ported Smiling Jacks Horn EFI system 10k+RPM
    '87 HydroStream V-King YT OMC 235 V6
    '77 Glastron CVX16-- Beaver Tyler built V4 Johnson
    Kona DayCrusier
    17' Contender
    XB03AllyProud on other sites
  1. Replies: 0
    Last Post: 04-06-2016, 09:49 PM
  2. Mercury ProMax 225 vs ProMax 225X. What are the differences?
    By stv1991 in forum Technical Discussion
    Last Post: 09-08-2012, 06:20 AM
  3. Top speed gain Promax 300X over Promax 300
    By Toffen in forum General Boating Discussion
    Last Post: 02-08-2004, 05:19 PM
