Results 1 to 9 of 9
Thread: 400r issue
    Apr 2009
    GA
    400r issue
    Have a single 400r on a flats rig, six months old. Yesterday I was pushing it pretty hard and when I backed off the throttle from wot in some turns then went wot again it was bogging around 5k rpm. Almost seemed starved for fuel or air. If you eased into the throttle it wouldn’t do it. Anyone have any idea what the issue would be?
    Sep 2017
    Ashland city tn
    Did it throw a code? Prob try scan it?
    Sep 2017
    ontario
    2.5 your on the money - SCAN - it an know - too far to dealer? Prop ?
    Sep 2017
    Ashland city tn
    Quote Originally Posted by kellytheaker View Post
    Hell with all tech goin into these motors, like a vehicle, scan it and see if it throwin sumthin , wouldnt b surprised if these things had check engine light nowadays haha
  5. Thanks KIRCHNER thanked for this post
    May 2008
    Merritt Island, FL
    pencil coils can act up and not throw a code
    Nov 2019
    Canada
    Quote Originally Posted by bradmd View Post
    Pencil coils can act up. I know on the smaller stuff you will feel the vibration, but maybe the 6 cyl you wouldn't as much. Theres something with the VST tank too, pump float switch or something can act up, killing the HP fuel pump. But yeah, your going to want to plug that guy in.
    www.InjectorService.com
    Call/Text - 204-326-0390
    Dec 2012
    Detroit
    Quote Originally Posted by InjectorService View Post
    verados 400 no float switch, as a matter of fact 2015-up Gen5 no more float switch on the VST. His problem is problably fuel related or like previously mentioned a coil going bad, or he could of had the rubber boot in the intake cracked.
    Big and slow
  9. #8
    Nov 2019
    Canada
    Thanks for correcting me, I was not aware of that.
  10. Likes XstreamVking liked this post
    Oct 2009
    Gonzales, La
    Some of these are experiencing the boost pipe between the compressor and the intercooler slipping out of the coupler. Might want to check that.
  1. 400R vs. 400R Carbon Edition
    By whytey in forum General Boating Discussion
    Last Post: 08-21-2020, 04:40 PM
  2. V8 400r
    By Toffen in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 03-21-2020, 02:10 PM
  3. 400r
    By NeedOne in forum Photos and Videos
    Last Post: 12-10-2017, 08:04 PM
  4. Mercury Tech: Dual temp gauges issue OR engine Issue
    By dompie99 in forum Technical Discussion
    Last Post: 05-24-2016, 09:37 AM
  5. 250xs top cowl melting common issue or is there an internal issue I should look for
    By 150aintenuff in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 08-30-2015, 05:14 PM
