Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 61
    Apr 2016
    Port perry
    Hydrostream core
    Well boys and girls finally got my hands on a vking now I already know all about the core rot and stringers that every original stream has but my question is this is the second owner selling it to me and hes not 100 percent sure if the marina that put the new floor in for the first owner did the core or not so what would the best way to check if it's been done or rotted drill a 4in hole in the new floor in the front or under the gas tank and then drill into the core and see what comes out?
  2. Likes tnelsmn liked this post
    Usually rot worse in the back area. One hole on either side 1' from centerline and 1' off the stern. That should put you in the worst of it.
    What year is it?
    Aug 2015
    Southeast
    You can buy a moisture meter at Lowes for $50. Some of the hydrostreams had the core completely disintegrate over time though. Just a void in between the fiberglass layers at that point. Moisture meter wont tell you anything if that's the case.
    STV ProComp w/ 225 Promax
    STV Procomp with 280
    25 Liberator "The Battleship"
    Blazer 650 Pro Tour
    Apr 2016
    Port perry
    87 canadian addition Click image for larger version.
  6. Likes TwzteD liked this post
    Apr 2016
    Port perry
ID:	468250Click image for larger version.
    Apr 2016
    Port perry
    Apr 2016
    Port perry
    How thick is the original core so I know not to go to far and put a hole in my gel i will more then likely just break the the glass and see just to be safe. Also I I stuck a little camera up through the drain hole would I be able to tell if the stringers were original
    Niiice find. Congrats on it. I don't know how the Canadian guys built them. The later US ones had a fiberglass box stringer in the center. That was all, and all it needed. Mines an '83' and has the box. The core should be 1/2'' thick with 1/8'' of glass over it.
    Apr 2016
    Port perry
    So would the middle stock stringer go right over the drain plug or stop short?
    Apr 2016
    Port perry
    Does anyone have a pic of a vking with the floor or and stock stringers
    The stringer stops short of the transom.
    Jul 2011
    Peterborough, On
    This is a Canadian Edition Vision, should be very similar to how a V-King was laid up here. They were generally built better than American boats, but the core should still be checked. Mine is an 88 and was in great shape when rebuilt.
  15. #13
    Apr 2016
    Port perry
    So should I drill one hole in the middle or one on either side of the stringers
  16. #14
    Minneapolis MN
    Quote Originally Posted by 91 charger stv View Post
    I think all three would be a good idea.
  17. #15
    Dec 2001
    Don't risk ya life.....I was working at a good speed shop.... not going to call names.....A guy comes in....HURTING...….his bottom blew out at 110...….went thru the deck..... ouch if ya to play .. speed prepay the MASTER do it right...
  1. hydrostream hst core
    By Gassman109 in forum Technical Discussion
    Last Post: 12-07-2016, 08:21 AM
  2. hydrostream Vector core
    By scottmcbx in forum Technical Discussion
    Last Post: 10-06-2014, 07:47 AM
  3. Hydrostream venus core
    By R.I.P. in forum General Boating Discussion
    Last Post: 03-29-2013, 07:44 PM
  4. Hydrostream re-core help
    By FusionFab in forum Fiberglass and Composites Discussion
    Last Post: 04-06-2012, 01:34 AM
  5. new core in the hydrostream
    By cuffer22 in forum Fiberglass and Composites Discussion
    Last Post: 03-07-2008, 06:02 PM
