Results 1 to 14 of 14
Thread: OMC 75 prop
    Mar 2009
    Virginia
    OMC 75 prop
    So I was looking for something in the garage and on the shelf I found a prop I used to run in EP class in the early 80's. It was built for my 13 Critchfield with a 75 OMC by DAH, if I recall correctly that was Don Henrich. Any one use these now?
    Sep 2011
    Scotland
    Is it 13 spline? Do you know the pitch/diameter?
    Mar 2009
    Virginia
    I will have to check next week when I go to where I keep my boats.
    Sep 2011
    Scotland
    Thanks, interested
    Feb 2006
    Brick NJ
    Pics and Info. I have a 13' bullet with a 70 I 'd like to try that on. THanks.
    Mar 2009
    Virginia
    I will post what information when I am down at the river. I know I can measure the diameter but to the best of my recollection the prop pitch was 21 before DAH started to work them. I dont know exactly what it ended up being. I believe it is still in its original OMC box I but right now I cant say for sure. This prop was used for circle racing so its gonna be a for acceleration, handling, and speed than just top speed.
    Thanks.
    Mar 2009
    Virginia
    I was mistaken. I had totally forgotten about this prop. It is NOT one of my old race props. It is a DAH 13x27 #386485 over the hub cleaver that I had build for my 140 OMC/Hydrostream Viper for running on the river.
  8. Likes 99fxst99 liked this post
  9. #8
    Nov 2003
    Portsmouth VA
    Quote Originally Posted by tideten View Post
    Did you want to sell this? Where in Virginia are you located?
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
  10. #9
    Mar 2009
    Virginia
    I am located in Richmond and the prop is currently located near Burgess Va in the Northern Neck. I still go there almost every weekend even in winter. The prop has been sittin in the box since I sold the stream in the late 80s so I dont think there is much of a chance I will ever use it again.
  11. #10
    Sep 2007
    Saginaw, MI
    I am looking for a prop for my 10.5ft cat with a stinger 75 15" shaft nitro gearcase.
    http://i35.tinypic.com/epn6ma.jpg
    Just a little Cat.
    24 Twister V8 E-Rude (For Sale)
    2008 Concept Sport Deck 2x 300X
  12. #11
    Mar 2009
    Virginia
    I have been out of performance boating for a long time so I have no idea. This prop is quite a bit bigger than what I ran in EP which was something like 12 1/4 x 21-23. We had a minimum weight of 840lbs and ran only a couple of pounds over that but the 75s had to be pure stock.
  13. #12
    Apr 2010
    oakville
    Is this prop still available?
  14. #13
    Aug 2019
    Palmharbor
ID:	503009Click image for larger version.
ID:	503010Click image for larger version.
ID:	503011I’ve got this clever and 13 3/4 x23 is on yellow lidClick image for larger version.
ID:	503012this last one is a 24 p
  15. #14
    Apr 2010
    oakville
    Prop availability
    Quote Originally Posted by MrG View Post
    Is this OMC 384137 prop 13.75 X 25 and is it still available if so how much and your location please PM at wcorrigan@gmail.com
  1. F1 / F2 Racing Items for Sale!! Dewald props, Performance Prop, Prop test wheel...
    By Spectre Powerboats in forum Misc. Parts and Accessories
    Last Post: 02-20-2018, 03:01 PM
  2. Replies: 1
    Last Post: 02-03-2018, 02:08 PM
  3. OMC Tech: Help! 225 carbed Johnson melting prop hubs / high exaust temps through prop hub
    By Tunnelvision1995 in forum Technical Discussion
    Last Post: 09-12-2017, 08:03 PM
