Results 61 to 63 of 63
06-30-2020, 08:48 AM #61Junior Member
- Jun 2020
- Pensacola
- 29
- 18
I will try a different gauge and report. The heads are new from hydrotec. Definitely cut down but I assumed a standard and usable amount. Idk.
Also. Can a bad crank shaft seal cause these kind of issues? I have been noticing a slight growling/squeeking when I have the cowl off running. After watching a bunch of you tube videos about what a bad crank bearing sounds like I think my upper one may be on the way out. That'll give me a reason to tear it down and replace all the bearings I may have damaged with water.
06-30-2020, 08:58 AM #625000 RPM
- Jul 2004
- ontario
- 182
- 18
- 59
- 24
06-30-2020, 10:09 AM #63
Can he double head gaskets?
Azure AZ259, 8.1
Hydrotec Yamaha heads
By Blue25 in forum Misc. Parts and AccessoriesReplies: 2Last Post: 12-12-2019, 11:08 AM -
'75 V4 crossflow just installed CCM reeds and block stuffers
By pcrussell50 in forum General Boating DiscussionReplies: 4Last Post: 11-01-2016, 07:57 AM -
Yamaha Tech: Stock 2.6 Yamaha instal HT8200 Hydrotec heads ? Jet sizes
By darkdream in forum Technical DiscussionReplies: 15Last Post: 10-29-2016, 02:37 PM -
Swapped power heads and lost tach- merc 2.5 lt 2002
By CircleHook in forum Technical DiscussionReplies: 0Last Post: 10-21-2014, 06:11 AM -
yamaha excel (hydrotec or boyesen reeds)
By aaronmt73 in forum Technical DiscussionReplies: 2Last Post: 11-01-2006, 10:03 AM
