Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 63
    Quote Originally Posted by Degan View Post
    I wasn't able to go out and retest yesterday it started raining and didn't stop.. today is drain the tank day. Got some buddy's coming to get some gas for their cars. Lol. I figure whether its the cause of this or not I need to put 93 in the boat. The toleune is just not going to be cost effective. Sourcing it here is $10 a gallon a least. Thanks for all the help I will keep you posted.
    Yes, you're 35 - 45 psi over the stock compression... "approximately" 90-octane probably isn't going to do the job; I would think 93 would be the bare minimum?
  2. Thanks Degan thanked for this post
  3. #17
    Jun 2020
    Pensacola
    Is 150 psi race gas territory? You think I need to do 93 and some of this toleune? Whew! Fishing is going to be expensive now. Lol
  4. #18
    Jun 2020
    Pensacola
    motv18. Turn the fuel up? How do i do that?
  5. #19
    I'm sorry, I don't know your motor, but I would think 93 would be to lowest you should go.
    You have a knock sensor protecting the engine so the thing to do would probably be to try the 93 and see what your top speed is (assuming it runs ok)... then try higher octane and see if it's faster?
    If not then you're not being limited by the knock sensor & low octane... if higher octane improves the top speed they you have to keep going up in octane until you find the sweet spot.
  6. Thanks Degan thanked for this post
    Likes FMP, Degan liked this post
  7. #20
    Minimum Shell 91 no alc I would think
  8. Thanks Degan thanked for this post
  9. #21
    Sep 2006
    Key Largo, Fl
    ? have you choked off one throttle body at a time to see if the power loss is on all cylinders,or confined to one or two?,Chris
  10. Thanks Degan thanked for this post
  11. #22
    Jun 2020
    Pensacola
    Chriscarsonmarine. No I haven't been able to yet. Bad weather since I posted this yesterday.
  12. #23
    Quote Originally Posted by Hutsss View Post
    Buy real premium 93-octane gas
    Real 93 has about 10% toluene unless it's jacked with alcohol
  13. #24
    Sep 2006
    Key Largo, Fl
    lets find out before you get much further...
  14. Thanks Degan thanked for this post
  15. #25
    Jun 2020
    Pensacola
    Quote Originally Posted by ChrisCarsonMarine View Post
    That's the plan. Fuel just seemed like a necessity regardless so I figured I'd handle that while I wait for sunshine.
  16. Likes David - WI liked this post
  17. #26
    Don't let your Lucas MMT get exposed to sunshine, it'll break it down. Don't let it sit mixed in a plastic jug without being covered with a solid blanket.
    Mix your fuel after the sun goes down.
  18. Thanks Degan thanked for this post
  19. #27
    Jun 2020
    Pensacola
    All the old fuel with the lucas booster in it is in other people's cars now.. not my problem anymore. Lol. I didn't know that tho. Thanks.
  20. Likes David - WI liked this post
  21. #28
    Onward!
  22. #29
    Jun 2020
    Pensacola
    I work near the water so the boat is coming with me tomorrow. If its not raining I should have some answers later in the day. Just finished refilling the tank with 93. That hurt a bit.
  23. #30
    Jun 2020
    Pensacola
    So I've got some news! Got on the water today with fresh 93 and boat did the same thing. 4k and nothing more. I'm by myself so I rigged up a pole with a t-shirt tied on the end to choke off the throttle bodys. I took off the silencer and proceeded to run it back up and notices the vent hose from the foot (previously plugged into the silencer) was spraying water put of it.. more rpm more water. This time without my water injection hose running to the intake it spins up to 4800ish and about 50mph. Also my t-shirt pole was not very helpful in choking cylinders as I saw no change from any of them. I guess I just have to wait until I have someone to help drive while I experiment. Now I have to find out why I have water rushing from the foot too. New sei unit just a few hours out of breakin. Any ideas? Thanks.
  1. Hydrotec Yamaha heads
    By Blue25 in forum Misc. Parts and Accessories
    Last Post: 12-12-2019, 11:08 AM
  2. '75 V4 crossflow just installed CCM reeds and block stuffers
    By pcrussell50 in forum General Boating Discussion
    Last Post: 11-01-2016, 07:57 AM
  3. Yamaha Tech: Stock 2.6 Yamaha instal HT8200 Hydrotec heads ? Jet sizes
    By darkdream in forum Technical Discussion
    Last Post: 10-29-2016, 02:37 PM
  4. Swapped power heads and lost tach- merc 2.5 lt 2002
    By CircleHook in forum Technical Discussion
    Last Post: 10-21-2014, 06:11 AM
  5. yamaha excel (hydrotec or boyesen reeds)
    By aaronmt73 in forum Technical Discussion
    Last Post: 11-01-2006, 10:03 AM
