Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 16 to 30 of 113
Thread: MercRod????
    BTW .. that thrust face looks good .. in tarnished , burnt silver .. huh .. ???
  2. #17
    Dec 2001
    Chazz the mannn….good read......I like the 3.4 newer rods...….
  3. #18
    8 Post(s)
    does anyone crack test rods?
    what method do you use?
  4. #19
    Yes , cranks too ..
    Mine is an older twin magnet , iron powder particulate spray model .. works good .
    https://goodson.com/collections/magnaflux
    If I ever have any doubts , about a scratch really being a crack . My friend's auto machine shop has a big cabinet model Zyglo (black light , green slime) tester ..
  5. Thanks powerabout thanked for this post
  6. #20
    MIAMI FLORIDA
    Any one ever do roto-peen, kinda like a flap wheel with #330 shot bound to the flaps used in a die grinder. That's what we used at the round engine shop for small parts and to finish grind out/ weld repairs. No need to mask or cover anything if ur careful. I have done all my motors like this. yea i got lazy at the thread area.. Oh yea omc not merc and we can crack test at +9k foam mercry cant get there....
  7. #21
    Well Dave , they say if ya learn sumptin , it was a good day . I got mine in before 8:30 this morning .. thank you for that ..
    Do you have a single flap on a mandrel , or the air motor / folded flap .. ?
    Don't ya gotta have Yamaha ignition .. or aftermarket ECU to get an OMC there ..
    The foam motors don't need to spin to 9K+ , cuz they gotz enough stroke to make the same power @ 6500 ..
    Besides , at anything more ... the toothpick styro rods start sawin the block in half … "axe" me how I know …
    G-man stuck his finger thru the "slot" an spun what was left of the big end. Said , cranks still good ..
    https://www.ebay.com/i/333224790297?...6540a16dde7a42
  8. #22
    MIAMI FLORIDA
    Now for the bad news the little flappers are super expensive 3m owns the technology but i have a source that can get them every time a big mil job comes around and every once in a while they pop up on ebay cheap. I use the little ones like in the top pic. There is a whole process to do it by the book...where you set the rpm on the grinder with a regulator and hit a test metal strip until you get full coverage with deformation of the strip, but we found as long as you set the die grinder speed down to a point where the strips last a descent amount of time and get the dings on top of the dings using a circular motion for full coverage its good...
  9. #23
    MIAMI FLORIDA
    Hitting an area like the rod bolt hole at the wrong angle will shred one real quick like the one i trashed in the pic, its a learning curve. You can usually get one rod per flapper if your careful..
  10. #24
    Dec 2001
    Shimmazddo…. I did em by hand...…..HeeHee…..
  11. #25
    South Africa
    Chaz, impressive work and knowledge! Need to do a set of 141 rods myself. What shot-peening spec do I have to tell the specialist?
    Rgds, Wolfgang (South Africa)
  12. #26
  14. Likes powerabout liked this post
  15. #28
    Dec 2001
    Drrnn things have changed up...…..still thimgz go BOOM
  16. #29
    MIAMI FLORIDA
    Yup, everything on that table prob cost more than my whole motor...
  17. #30
    Quote Originally Posted by H2OPERF View Post
    A little too aggressive for my liking .. but even the cabinet will turn the shot into powder with too much air pressure .
    wolfgangb
    Thank you sir .. I have been using a mix of 170 and 230 . A good balance between getting a peened surface and beating up the blaster . Porcelin cups and cabinet glass go away at an alarming rate ..
