Results 16 to 30 of 32
    Gothenburg, Sweden
    Quote Originally Posted by Aaronhl View Post
    They are just ok... have to be modified out of the box for an outboard to mount on them safely.
    First of all the plate they give you is not big enough for the top holes of the clamp so you have to use the extensions. Those extensions are barely big enough so they need to be adjusted still with the risk of the bolts loosening and then the engine drops if they do.
    So you need to make a piece of metal (maybe wood) to use to bolt to the plate which will then bolt to the upper engine mount holes.
    It is still not high enough to mount a 25" for those that convert to 20's or dont take the lower unit off right away, so you have to raise the post, which is more work, or build the top metal bar piece taller.
    Got it. The one I have has none of the deficiencies described above, but I stay away from 25" mids...__PRESENT
  2. #17
    Jun 2009
    Bristol, Connecticut
    Be careful if the wheels are not extended in front of the post, had an engine fall forward as I was lifting the back of it. Hopefully with the wheels in front of the wooden stand I made it will not fall forward as easily
  3. Likes LakeFever liked this post
  4. #18
    Plainville, CT
    Wow I hope no one got hurt when that engine fell forward.
    I've had good luck with my metal one but never tried a 25".
  5. #19
    Jun 2009
    Quote Originally Posted by Glastron1987 View Post
    Yea your 135 fell without damage or injury....
  6. #20
    Plainville, CT
    That's good, but next time drop a 200 for me.
  7. #21
    Jun 2009
    Got an engine up on the stand so I could drill the bracket holes. When the motor is hanging in the air the transom bracket its tilted, no problem because it's pretty easy to put an engine on this stand. It hooks up on the top as I lowered the hoist and then I push the stand into the engine(forces the engine to tilt flat into the stand) while I put the bolts in.
    As far as safety, It will take a lot of movement for an engine to fall off this stand, I dont think I have the strength to do it even, it is very balanced. And it is very easy to maneuver around the garage...
Name:	engine stand 3.jpg
ID:	470321Click image for larger version.
Name:	engine stand 2.jpg
ID:	470322Click image for larger version.
Name:	engine stand 1.jpg
    sorry the pictures are rotated
  8. Thanks LakeFever thanked for this post
    Likes tux974, rgsauger liked this post
  9. #22
    Nov 2019
    Canada
    WOW, that stand is definately HD. Looks a lot nicer than anything I have ever made.
    www.InjectorService.com
    Call/Text - 204-326-0390
  10. Thanks Aaronhl thanked for this post
  11. #23
    Jun 2009
    Quote Originally Posted by InjectorService View Post
    Thank you! Def H.D., compact and easy to build!!
  12. #24
    Plainville, CT
    Looking good!!!
  13. Thanks Aaronhl thanked for this post
  14. #25
    Sep 2011
    maryland
    Quote Originally Posted by Markus View Post
    What's wrong with the standard steel engine (or is it gearbox) stands on wheels which you can buy at the auto stores?__PRESENT
    Nothing wrong with them at all. But I can build a motor stand for much less using a cheap dimensional lumber(pine) and a set of caster off Amazon., and smaller footprint to boot. Heck I usually have some leftover wood from a project i had to do, when I need to build one.
  15. Likes Aaronhl liked this post
  16. #26
    Minneapolis MN
    Mine has been sitting on this old POS stand for 2 years. Always nervous when moving it around as its very unstable. It wants to tilt left or right cause the pivot pin is loose, then the engine swings left or right on the swivel bracket. Probably could've charged money to watch me pull the lower unit out of it yesterday. Like a monkey trying to f**k a football as the saying goes haha. I'll feel a lot better once the powerhead comes off in a few weeks.
  17. Thanks Aaronhl thanked for this post
    Likes Aaronhl, mrichartz, rgsauger liked this post
  18. #27
    Nov 2019
    Canada
    Wow, I had never thought of doing that. Also never heard that saying before. You learn something new everyday I guess! Haha
  19. Likes tnelsmn liked this post
  20. #28
    The wood stands are so strong that I put powerheads on the front deck part along with an engine on the uprights to make the stsnds even more stable. I guess 750 lbs. total.
  21. Likes tux974 liked this post
  22. #29
    Looking good! These wood stand hold up plenty and if you use good casters they roll really easy.
  23. #30
    Houston, TX
    Looks great. I like that!
  1. Engine stand
    By 2.5-21 in forum General Boating Discussion
    Last Post: 12-01-2013, 11:07 AM
  2. engine stand
    By JWS in forum General Boating Discussion
    Last Post: 02-27-2010, 11:12 AM
  3. Replies: 0
    Last Post: 05-08-2006, 08:15 AM
  4. DIY Engine Stand?
    By speedyfast in forum General Boating Discussion
    Last Post: 12-17-2005, 02:04 PM
