Results 1 to 1 of 1
    Nov 2019
    Stuart FL
    Question Verado PCM/ECM swap
    Hi guys I have a set of 2005 Gen 1 225 verados and I am definitely under powered. I was originally looking at the simon tune and finally decided to bite the bullet last week called them and was told they no longer tune verados talk about a huge bummer. I then reached out to whipple and usp marine tuning and got the same response. As far as my options go:
    1) Is there anyone else out there that is well known for reliably tuning Vrods other than those mentioned above?
    2) If I were to pick up a set of Gen 1 275 PCM's to replace mine, what part numbers should I be looking for? and is there anything else I would need to do other than just swapping the PCM? (engine serial numbers: starboard 1B030515 and port 1B030521)
    thanks in advance I greatly appreciate it.
  1. 1987 48 spl carb upgrade options
    By ALBASS in forum Technical Discussion
    Last Post: 09-02-2018, 05:03 AM
  2. 1999 mercury 200 carb upgrade options
    By Worleybird97 in forum Technical Discussion
    Last Post: 08-27-2018, 09:46 PM
  3. 150 Verado ECU upgrade
    By jonesyfxr in forum Technical Discussion
    Last Post: 10-02-2015, 06:30 AM
  4. Merc 225 upgrade options
    By P4-33 in forum Technical Discussion
    Last Post: 05-14-2014, 12:15 PM
  5. ECM upgrade for Verado 150
    By Kias in forum General Boating Discussion
    Last Post: 08-27-2013, 01:45 PM
