Results 1 to 1 of 1
06-14-2020, 01:53 PM #1New Member
- Nov 2019
- Stuart FL
Verado PCM/ECM swap
Hi guys I have a set of 2005 Gen 1 225 verados and I am definitely under powered. I was originally looking at the simon tune and finally decided to bite the bullet last week called them and was told they no longer tune verados talk about a huge bummer. I then reached out to whipple and usp marine tuning and got the same response. As far as my options go:
1) Is there anyone else out there that is well known for reliably tuning Vrods other than those mentioned above?
2) If I were to pick up a set of Gen 1 275 PCM's to replace mine, what part numbers should I be looking for? and is there anything else I would need to do other than just swapping the PCM? (engine serial numbers: starboard 1B030515 and port 1B030521)
thanks in advance I greatly appreciate it.Last edited by Jawsspearguns; 06-16-2020 at 05:28 PM.
1987 48 spl carb upgrade options
By ALBASS in forum Technical DiscussionReplies: 9Last Post: 09-02-2018, 05:03 AM -
1999 mercury 200 carb upgrade options
By Worleybird97 in forum Technical DiscussionReplies: 8Last Post: 08-27-2018, 09:46 PM -
150 Verado ECU upgrade
By jonesyfxr in forum Technical DiscussionReplies: 0Last Post: 10-02-2015, 06:30 AM -
Merc 225 upgrade options
By P4-33 in forum Technical DiscussionReplies: 9Last Post: 05-14-2014, 12:15 PM -
ECM upgrade for Verado 150
By Kias in forum General Boating DiscussionReplies: 0Last Post: 08-27-2013, 01:45 PM
