Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 36
Thread: Digital ECU
    May 2008
    KEYSTONE HEIGHTS FL./ Moncks Corner Sc
    Digital ECU
    I want the most recent version Mercury digital ECU for a 300 drag. Who has them available? Not going to use Brucato.
    The evidence of poor quality lingers much longer than the success of meeting a budget.
    7 Post(s)
    Call Mercury Racing if you want parts they produce , or had made for them once apon a time. If / when , sticker shock or they just blow you off , try >
    Monty Racing is a dealer for the new FuelTech ECU dashes . Independent fuel and spark control built into the dash pod.
    https://www.fueltech.net/
    Feb 2007
    lily lake WI
    Do you want the programmable mercury 849 or the new merc digital a13 those are not programmable another option is Brendan power has a new ecu that is coming out shortly and it is a really good one
    May 2008
    I have a 849 that has taken a dump, way too rich, wanted to try the A13. I have no idea why the 849 went south. Going to replace chip with one from Marles but I’m not sure it will clear up my issues. It’s a cheap enough option to try.
    Jun 2012
    Indiana
    849's don't take a chip. You probably have a 11350.
    Apr 2007
    Big Pine Key, Fl
    Quote Originally Posted by MUDSHARK View Post
    ..If you have a DDT,,plug it in and the temp readings should be your local area temps,,,if your temps say 225 your temp sender in ecu is bad,,,it will run rich.Check the M.A.P
    sensor reading....base line from merc is 160 on 4 button and 14.6 on otc or merc with cartridge..Your ecu can be repaired if those sensors are bad.
  7. Likes MUDSHARK liked this post
    May 2008
    Who can repair the ECU if the sensors are bad?
  9. #8
    May 2008
  10. #9
    Feb 2007
    lily lake WI
    Quote Originally Posted by capteliminator View Post
    The 849 still have prom chips
  11. #10
    Jun 2012
    Indiana
    My bad, I have 2 of them and didnt know that!
  12. #11
    Apr 2007
    Big Pine Key, Fl
    Quote Originally Posted by Michael J Giesler View Post
    .......no...only 11350 ecus have chips....The 849 a6 and a13 are the ecus
    that are able to be reprogramed,they still have the M.A.P sensor that can be replaced if bad.......
  13. #12
    The 11350's have removable Chips that can be replaced as you and I both know. The 849849 A6 has a PROM (Programmable Read Only Memory) chip (its PROM code is 7119) its manufactured as blank memory then programmed but its potted and cant be removed but can be reprogrammed. The 849849 A 13 doesnt have a Potted PROM Chip. Its a ROM (Read Only memory) and is Programmed during the Manufacturing process and cant be reprogrammed.
    Quote Originally Posted by laser_ED View Post
  14. #13
    Feb 2007
    lily lake WI
    The 849 still have chips in there prom 71 73 76 and a drag f1 champ and are interchangeable you can burn the chips for whatever prom you want can you replace them
  15. Likes Capt.Insane-o liked this post
  16. #14
    Did 2 fattened a6 chips last week
  17. Likes Michael J Giesler liked this post
  18. #15
    Apr 2007
    Big Pine Key, Fl
    OK,I just opened an A6 ecu and a A13 ecu,they both have a removable chip that you can program...Why would you remove it to { fatten it up},when you can do it via a computer program?
  1. WTB- Digital Delay-Digital Trim Timer
    By TripleA in forum Parts Wanted
    Last Post: 03-07-2016, 11:25 AM
  2. Digital SLR or not?
    By Mike2002 in forum Media Creation - Photo and Video Discussion
    Last Post: 07-21-2005, 06:09 PM
