Results 1 to 2 of 2
    Dec 2006
    Center engine height on cat
    When it comes to the center engine on a cat rig what is the best engine height for the best top end results. The cat does have the hull water defuser for the center engine (I don’t know the correct name for it).
    Pod is the term. Height is best determined by testing but should be just skimming the surface as general rule. And usually needs a hull mounted water pickup.
  1. need help setting my engine height and jack plate height
    By johnsongt175 in forum Props, Setup, and Rigging
    Last Post: 05-27-2014, 07:21 AM
  2. F2 Leecraft Engine set-up ( engine height )
    By MirageBoy69 in forum Props, Setup, and Rigging
    Last Post: 10-30-2011, 07:47 PM
  3. Building new 22' center console cat. Need engine height, prop advice.
    By Mini Max in forum Props, Setup, and Rigging
    Last Post: 09-27-2009, 07:19 PM
  4. HOW to - jack plate height/engine height
    By Techno in forum Technical Discussion
    Last Post: 08-21-2007, 12:49 PM
  5. Engine height w/notched transom Fountain Center Console
    By Mr. Demeanor in forum Technical Discussion
    Last Post: 07-24-2007, 08:37 AM
