Results 1 to 13 of 13
06-14-2020, 05:19 AM #1
Frank Molé, tunnelmike liked this post
06-15-2020, 10:13 AM #2
You have any bare blocks? Or would you be willing to sell one without all the EFI components?
1990 Collins Mirage - 15" 260
25 hp Merc with dry side pipe
06-16-2020, 05:06 AM #3
07-07-2020, 05:34 AM #4
Things left....10/14/20
A very clean straight leg mid sections, Hi-Perf late style single ram saddles, 2.5 2pc plate, wide exhaust ports, solid mounts, drilled cans, 1/2" tiller bolts, with new Bob's tuners.....$950.
1- clean, serviced LH, straight skeg, 1:87, 4 hole, wide passage CLE.....SOLD
1- clean empty straight skeg, 4 hole, wide passage, CLE bare aluminum....SOLD
1- clean cowling Top & Pan with SS pan plate...NO skirt..........SOLD
***I have trim pumps and OEM hoses if needed it.
***set of 2pc plate side steering MM plates (in picture)....$400 for set.
Frank Molé liked this post
07-07-2020, 08:02 AM #55000 RPM
- Dec 2011
- united states
- 494
- 7
- 7
- 25
Tony, do you have any factory 1pc plates for a promax? Or Any alien cowlings, RH lowers swept skeg? Hope all is well! I gave you a shout yesterday might be looking for some miscellaneous things as well.
All the best,
Cory
07-07-2020, 08:40 AM #6
10-01-2020, 02:02 PM #7New Member
- Sep 2020
- Bermuda
Is this complete 2.5 200 still available?
10-02-2020, 04:57 AM #8
10-11-2020, 05:24 AM #9
Below is what I have left 10/11/20
I have a very clean straight leg mid sections, Hi-Perf late style single ram saddles, 2.5 2pc plate, wide exhaust ports, solid mounts, drilled cans, 1/2" tiller bolts, with new Bob's tuners.....$950 each.
A very clean, serviced LH, straight skeg, 1:87, 4 hole, wide passage CLE.....$1200...NOTE; The skeg looks short but is not, it's just the picture
A set of 2pc plate side steering MM plates (in picture)....$400 for set.
10-13-2020, 10:34 AM #10Registered User
- Aug 2009
- mich.
hello interested in lower
10-13-2020, 10:51 AM #11Registered User
- Aug 2009
- mich.
interested in lower
10-14-2020, 05:13 AM #12
10-15-2020, 05:40 AM #13
CLE is SOLD
Power Heads?
By lancer in forum Technical DiscussionReplies: 1Last Post: 07-18-2010, 04:43 PM
